Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-10-2020, 11:48 PM
frankyboy455 frankyboy455 is offline
Default Doug Nash 4+1 or Richmond parts wanted
I'm looking for parts to repair a Doug Nash/Richmond 4+1 5 speed transmission that I bought. I need the input shaft (gm 26 splines) and the 5th cluster gear.
Let me know what you have, used or new.
Thanks,
Frank.
Old 11-18-2020, 08:52 AM
Anyone ?
Old 11-18-2020, 03:38 PM
marxjunk marxjunk is offline
theres a dude in texas that has parts..he fixed the t56 in my CTS-V..and is the most reliable guy i ever dealt with long distance for that type of service...good dude..
drawing a blank on his business name, i will dig the receipts out..when i talked to him in January he said he could fix the DN i have, no problems..he fixed my T56 and it is flawless..ill be back here tonight after i get home..
he said he can fix them and get any part needed and he will sell parts
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 11-18-2020, 06:19 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Would like to know the name of this entity as well! I have one w/ very low usage sitting on the shelf. Grinds going into 5th....
Old 11-18-2020, 08:33 PM
63gpman's Avatar
63gpman 63gpman is offline
https://www.5speeds.com/ guy from this site has a few youtube vids on how to improve shifting of these transmissions. Sounds like they stock some parts, may be worth checking into.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 11-18-2020, 10:52 PM
https://www.texasdrivetrainperformance.com/
good dude..he let me use his shipper and saved half..
i cant tell you enough about how good he was to me..and the number 1 thing, it was back 2 days before he said it would be..it got there, they tore it down, called me, i ok'd it and bam it was done..
thats impossible long distance..so it was very refreshing
Mark..
The Goat whisperer
Old 11-19-2020, 12:03 PM
Thanks !
Old 11-19-2020, 01:11 PM
Tom Vaught's Avatar
Boost Engineer
Last time I thought about this subject, I remembered Leonard Long who made the excellent Leonard Long Shifter" for the Nash and Rechmond Transmissions. Leonard had a bunch of Nash and Richmond Transmission parts.
His company is called "Long's Machine" Cleona, Pennsylvania.
He has another compant called Long Shifters (717) 202-8374
(This info is a few years old.)
Tom V.
Old 11-19-2020, 07:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Richmond used to carry a number of parts a few years ago but would not sell direct. I got mine from DTS when I freshened and changed ratios on a race Nash 5 speed. Ihave parts schematics I can copy if you need. If you do decide to try working on it get a GOOD pair of big snap ring pliers! Not cheap Chinese.
Skip Fix
Old 11-19-2020, 11:59 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Jegs carries any part you need that is made. The trick is to know the Richmond part numbers. Through mergers and acquisitions. Motive Gear now owns them. I've been through a few DN/ Richmond 4+1 units. Very simple. All serviceable parts (rings, bearings seals ec) are readily available and are in multi use applications. Rev Gear & idler is usually kissed and needs replacing. This is available.
