Old 01-28-2021, 05:46 PM
jjs jjs is offline
Question Disc brake calipers
Looking to convert 69 fb to disc brakes, can i use 2006 Corvette calipers?
Old 01-28-2021, 06:02 PM
JLMounce JLMounce is offline
You can with the correct brackets. If you need everything, Kore3 specializes in retrofitting corvette brakes to gm cars. It's not all that thrifty from them however.
www.kore3.com
Depending on what the usage is, it's still the best economically to go with something like a Right Stuff Detailing kit that uses mostly factory pieces.
If you have a street car only that does not see open track use, where repeated stops take place, the factory stuff is more then up for the task. Especially if you're running on old style 15" wheels and the types of tires available for them.
www.getdiscbrakes.com
-Jason
1969 Pontiac Firebird
Old 01-28-2021, 08:45 PM
jjs jjs is offline
Thanks for info, have 17" wheels, may not fit? Going to look into a kit.
Old 01-28-2021, 11:54 PM
The smaller c5 setups should fit most 17” wheels. C5’s has 17/18 staggered setup from the factory.
The c6 uses the same calipers but a larger disc.
If you decide to go with a factory type setup, you can also do the Wilwood d52 calipers which have a higher end look to them and are a direct replacement for the factory style single piston calipers.
-Jason
Old 01-29-2021, 09:32 AM
vertigto's Avatar
vertigto vertigto is offline
The Right Stuff has a number of conversion kits depending on your needs for 15"+ or 17"+ wheels and w/ and w/o a 2" drop...
https://www.getdiscbrakes.com/parts/...e-conversions/
Old 01-30-2021, 09:42 PM
jjs jjs is offline
I can get the calipers free! If I user a smaller disc will they fit my 17" rims. Like 11" or 12"?
Old 01-31-2021, 01:42 PM
JC455 JC455 is offline
The c6 uses the same calipers but a larger disc...
Mounting wise, the C5 and C6 calipers are the same. The C6 does appear to be a bit stronger because of the redesign of the cooling fins.
All pads are the same D731 for the front, D732 for the rear.
C6 and C6 Z51 are the same caliper, you just need a different caliper mounting bracket- Z51 is taller.
The rotor is larger 13.38 (C6 Z51) vs. 12.75(C5/C6), so a little more brake torque available. The Z51 rotors have the holes in them though- by now, there are some solid rotors available.
If you are going to convert to discs, you’ll need: brackets for either setup, rotors for either, pads for either, and a master cylinder/distribution valve for either.
The factory-style setup will require either machining your drum spindles or replacing them w/ disc spindles.
The Kore3 design for adapting Corvette brakes to your drum spindles will require a hub to mount the rotor. This is easily fabbed by using your front drum hub.
You’ll need to remove the brake drum from the hub, turn down the outside of the hub to fit inside the Corvette rotor, and replace the drum studs with longer ones.
Or they sell aluminum hubs. Either way, you now have slip-on rotor system that doesn’t require repacking bearing every time you surface/change the rotors.
The other benefit of the Kore3 vs. other brackets is Tobin designed his brackets so your wheels aren’t pushed out further.
You’ll need brake hoses that convert from SAE to metric banjo- he sells those at a good price.
I’m going to be doing a video on putting the Kore3 brackets on my 64 Tempest, but it’ll be a bit.
I do have some reference info on the C5/C6Z51 calipers/rotors/abutments on one of my videos.
https://youtu.be/rK1wKKkV3ws
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 01-31-2021, 02:23 PM
Pics tell a story-
A) Factory GM disc brake short spindle(knuckle) - A/F/X body
B) Kore3 adapter brake hoses
C) Kore3 GM drum short spindle to C5/C6 Corvette caliper bracket
ID:	559849   Click image for larger version
ID:	559850   Click image for larger version
John
Old 02-01-2021, 02:34 PM
EDIT* Upon reading further on Kore3's Billet Hub info, they DO move the wheels out .200" each side, so your track width is slightly increased.
John
Old 02-01-2021, 07:48 PM
jjs jjs is offline
Thanks for the info will chk kore3 site
The Following User Says Thank You to jjs For This Useful Post:
Old 02-20-2021, 09:25 PM
69FIREBIRD76MM's Avatar
I'm installing CPP 13" C5 brake kit on my 69 Firebird. I recommend you buy the ebay spindle but used better quality parts, like corvette C7 Hubs/bearings, brake pads, brake rotors, calipers from C5, C5, Zo6 or Wildwood. Jm2c
ID:	561239   Click image for larger version
Name:	$_1 (1)(1).jpeg
ID:	561240   Click image for larger version
The Following User Says Thank You to 69FIREBIRD76MM For This Useful Post:
