Old 06-09-2023, 04:45 PM
A390GT's Avatar
A390GT A390GT is offline
Default Dual Exhaust hangers
My Waldron dual exhaust for the 68 wagon finally came in. Anyone know where to source exhaust hangers? I can probably rebuild the one muffler hanger but I will need a second and the two that hold the tail pipes
Thanks,
John-
ID:	613966   Click image for larger version
ID:	613967   Click image for larger version
Old 06-10-2023, 08:15 PM
A390GT's Avatar
I was able to get one side done. Auto zone had a muffler hanger with the right size rubber strap to make the old hanger new again…I’m going to have to fab up the drivers side muffler mount if I can’t find another…
But i have some time now because I have to call waldren. They shipped 2 different sized mufflers. one is 14inches and the other is 17. The 14 is the one I used for the pass. Side. I only had to cut about an inch off the long down pipe to make it work. The 17 is just too big Id have to cut where a bend is to make it work…
ID:	614064   Click image for larger version
ID:	614065   Click image for larger version
Old 06-13-2023, 08:17 AM
A390GT's Avatar
So apparently a stock exhaust has a 14inch muffler on the pass. Side and the drivers side gets the 17…
Never knew that…
after a call to Waldron I had to take 2 3/4 off the drivers down pipe to make it work.
The Following User Says Thank You to A390GT For This Useful Post:
Old 06-15-2023, 01:03 PM
I believe only the A body duals had unequal length mufflers in 69. Sounds like Waldron made a mistake.
As for those hangers I’ve been only able to scrounge used ones and then replace the rubber. Now I’m reduced to fabrication of the metal bits..
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 06-15-2023, 03:59 PM
A390GT's Avatar
John at Waldron rechecked the card. And he said this is what he had for a 1968 catalina dual exhaust. I cut the 2 3/4 off the driver down pipe and everything lines up…
I was able to find the top peice that attaches to the frame with the rubber isolator. I just have to bend up the bottom peice this weekend…
Old 06-22-2023, 08:26 PM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
There is no one reproducing these I assume? They would probably be well received.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
Old 06-22-2023, 09:48 PM
Waldron told me no one makes those hangers.
You can sort of use the repro tailpipe hangers for the automatic transmission GTO’s to hang the tailpipe. On the plus side the two metal parts needed to make the B body muffler hangers are pretty easy to fab.
1969 Bonnie Cvt
