Old 04-14-2021, 11:36 AM
mrtonegto's Avatar
mrtonegto mrtonegto is offline
Default Shifter Positioning
I installed a TKO600 in my '65, I have found a Hurst bar that could be adapted to the TKO but need the correct positioning of the bar.
Based on a stock 4-speed Hurst bar in neutral:
- what is the height from the tip of the bar to floor sheet metal
- what is the distance from the tip to a measuring point on the dash
I will adapt the bar/mount to match.
Thanks for help!
Tone
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine"
1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS
Old 04-15-2021, 08:50 AM
mrtonegto's Avatar
OK, how about just from the tip of the shift ball to the dash??
Old 04-15-2021, 01:43 PM
geeteeohguy's Avatar
What is a shift bar? I know of shift rods and shifter handles. Never heard of a 'Hurst Bar'.
Jeff
Old 04-15-2021, 02:42 PM
gtopont gtopont is offline
Angry shifter
WHAT IS A HURST BAR ??????????????
Old 04-15-2021, 02:45 PM
Bill Hanlon's Avatar
My GUESS (no real knowledge) is a T handle on the top of a Hurst shifter.
Old 04-15-2021, 04:24 PM
Rich-Tripower's Avatar
I'm pretty sure BAR = HANDLE.
Old 04-15-2021, 04:33 PM
mrtonegto's Avatar
The lever - says "Hurst"
Thanks for asking
Old 04-15-2021, 09:43 PM
I didn't have time today. If I can remember, I can get you some measurement tomorrow.
Old 04-15-2021, 10:42 PM
mrtonegto's Avatar
Thanks, Rich
Old 04-16-2021, 12:11 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
OK , correct names for "Hurst" shifters- according to "Hurst"
Arms= brackets that are bolted to side of trans ,That the RODS, 1st + 2nd. And 3rd + 4th, are mounted in with bushing and spring clip.
Handle= the chrome stick with Hurst logo.
Then there are T handles and balls
Dave
Old 04-16-2021, 01:15 PM
mrtonegto's Avatar
Dave,
Not for nothin'..... but I'm honestly looking for the measurements.
Just turned 74, to correct all my improper and idiosyncratic grammer would take an entire forum....... nevertheless you are correct.
So how about it?
All in jest......
Tone
Old 04-16-2021, 09:13 PM
Sorry, didn't get up to the shop today. I'll get there tomorrow.
Old 04-16-2021, 09:31 PM
mrtonegto's Avatar
I appreciate it.
Old 04-17-2021, 10:45 AM
dhcarguy's Avatar
Originally Posted by mrtonegto View Post
Dave,
So how about it?
All in jest......
Tone
(LOL)
Tone,
from the front edge of my shifter ball to the very bottom of the dash is 7"
From the top of the ball (original ball) to the top of the carpet in front of the passenger seat (center of seat) is 18 1/4 "
Old 04-17-2021, 02:11 PM
mrtonegto's Avatar
Thanks, Dave!
Old 04-17-2021, 02:42 PM
Our car is a 64 GTO with its original Hurst shifter. Measurements can be seen in the photos. When the handle is further forward that is 1st gear, when the handle is further rearward that is 2nd gear.
ID:	564918   Click image for larger version
ID:	564919   Click image for larger version
Old 04-17-2021, 05:55 PM
mrtonegto's Avatar
Thank you, Rich!
Old 04-17-2021, 10:02 PM
Thank you, Rich!
Glad to help. Sorry it took so long.
