dowel bearings for pontiac rj
are these available anywhere? hows the best way to go about making holes if theyre not? i saved some old rod caps and thought about trying to drill and make a jig but if theres a better way
http://performerrpm.myphotoalbum.com/view_album.php? |
I have a stock rod cap that a machinest drilled and installed a drill bushing in it for me for my BME rods i can loan it to you, might want to verify same size hole first i can check tomorrow
A man who falls for everything stands for nothing. |
The Following User Says Thank You to Formulas For This Useful Post: | ||
what size bearings? you can buy a jig
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
im working with a set BME rods too
A drilled old cap works fine for me. Not enough use to warrant a drill bushing.
I've also bought pre-drilled bearings at times.
does the hole need to be exact in size or can it be just a little bit loose fitting?
It can be a couple thousands too loose since the dowel is there to keep the bearings from outright spinning during loads where the big end gets distorted .
It's not ment to replace Bearing crush, it's just the last line of defense against a spun Bearing. If the dowel hole is not dead on then it's better to have some play so that the ends of the Bearing line up the way they should at each parting line.
The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
the one i free handed was .003 off from being perfectly centered, but. the hole was exact and once i bolted the 2 halves together, the parting line match perfect but to me it looked like the bearing moved closer to the radius of the rod. i went a tad bigger on the hole and it gave enough to match it up both at the parting line and along the radius.....a jig should work wonders...i might just buy a drill press
Oh gez yes!
Trying to get it right without a drill press is not the way to do this.
lol , no i wasnt gonna. i was meaning i might get a drill press and try making my own jigs as well as do my own bearings. vs having them made at the machine shop.
I did the same when I ran pinned bearing aluminum rods-an old cast iron rod cap. Made a paper template of where on the luminum rod it was located and transfereed that to the rod cap. Then drill press for sure!
