Old 04-16-2023, 09:32 AM
vwalburn vwalburn is offline
Default Steering joint contact
My steering joint on my '64 GTO contacts my Doug's headers. Not too bad but can be felt through the steering wheel at times. What are some solutions to this? The headers already have an indentation at that spot but not enough. Is there a universal joint that can be installed?
Vince Walburn
1964 Pontiac GTO
Retired USAF SMSGT. 1983-2015
Old 04-16-2023, 08:48 PM
Goatracer1 Goatracer1 is online now
You could remove the rag joint and install a universal joint or you could just dent it some more.
Old 04-17-2023, 05:36 PM
Dick Boneske's Avatar
The bolts thru the motor mounts allow for some movement of the engine. If you loosen the two mounting bolts, you can pry the engine away from the steering box. A jack under the pan helps with this, but be sure to use a flat board to avoid damaging the oil pan.
BONESTOCK GOATS
'99 Bonneville SE Sedan
