Old 01-25-2024, 05:12 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Rusty Intake Manifolds
I want to clean some old cast iron intakes I have on the shelf...
They are as removed....with grease,old paint and rust......and some have some rust in the plenum under the carb mounting flange....
Just exploring my options....speed vs cost.....vs quality of job....
Electrolysis.......muriatic acid...media blasting.....Evaporust soak?
Done the wire wheel \ wire brush route before.....
Looking for some input.....Thanks
Old 01-25-2024, 05:22 PM
i82much's Avatar
i82much i82much is offline
wife.
The Following 3 Users Say Thank You to i82much For This Useful Post:
Old 01-25-2024, 05:30 PM
phil400's Avatar
phil400 phil400 is offline
I did this about 5 years ago, but I cleaned up a 72 intake with a wire wheel then soaked in plain ole white vinegar for a few days maybe a week then knocked off the loose stuff with a wire wheel after soaking, intake came out alright but my stuff idmsnt high dollar builds, included some before and after pics
ID:	627204   Click image for larger version
ID:	627205   Click image for larger version
ID:	627206   Click image for larger version
ID:	627207   Click image for larger version
78 T/A 4SPEED, Original paint, match #’s, mine since ‘99.
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
The Following User Says Thank You to phil400 For This Useful Post:
Old 01-25-2024, 05:32 PM
phil400's Avatar
More pics, afterI was done I used brake clean the coated it with WD till I was ready to paint
ID:	627209   Click image for larger version
ID:	627210   Click image for larger version
77 t/a sold
83 Mustang GT sold
Old 01-25-2024, 05:36 PM
phil400's Avatar
Another pic
77 t/a sold
83 Mustang GT sold
Old 01-25-2024, 05:44 PM
phil400's Avatar
Here it is painted, sorry for all the posts, was years ago had to go searching through my phone for the pics,I also painted the exhaust crossover with several andI mean several coats of high header paint to slow the engine paint burning off and rusting, several years some discoloration but no rust
ID:	627213   Click image for larger version
ID:	627214   Click image for larger version
ID:	627215   Click image for larger version
77 t/a sold
83 Mustang GT sold
Old 01-25-2024, 05:56 PM
1968GTO421's Avatar
When I was in AACA years ago, one of the guys used electrolysis, putting the part in a large tub with leads from a battery. One lead went to a clamp on the part and another to the metal tub (if I remember correctly). His technique worker great on some really funky parts. I really like Phil400's method as it does not involve electrical stuff and possible shocks to curious kids and others. Thanks, Phil.
GTOAA--https://www.gtoaa.org/
The Following User Says Thank You to 1968GTO421 For This Useful Post:
Old 01-25-2024, 06:33 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The exhaust crossover junk is something to be sure is all gone and not just loosened up to be blown into the ports on the other side regardless of what you use.
Skip Fix
Old 01-25-2024, 06:55 PM
mgarblik mgarblik is offline
If you have a machine shop in your area with a thermal cleaning process, that is simple and easy. They will look like new manifolds when they come out, inside and out. A shop around here would probably charge $50.00-75.00 to run a load. Our drum would hold maybe 6 intakes. So per manifold, pretty reasonable.
Old 01-25-2024, 07:10 PM
I local guy here quoted me $300...to run a load/batch....so I crossed that off my list.....
Does that process remove rust...or just paint/grease?
Old 01-25-2024, 07:13 PM
I'm just setting up to experiment with electrolysis......and also muriatic acid soaking.....
Old 01-25-2024, 07:15 PM
Thanks for posting all the pics/info....
I also have a 78 Ta that I've owned for a long time...
Old 01-25-2024, 07:40 PM
Apparently....Muriatic acid....will potentially damage intake if left too long in the soak...
Phosphoric acid would be a better choice..
Old 01-25-2024, 09:23 PM
That is a very high price. $300.00 worth of thermal cleaning here would do an entire engine. Block, heads, crankshaft, manifolds, and sheet metal. Typically 3 full loads. So maybe $100.00 a load now.
Parts come out like new castings from the foundry. No rust, paint or anything else, inside and out. We bake iron in a slow rotating drum at about 650 degrees F for an hour. Then it goes directly into a stainless steel shot machine with .030" tiny steel wire shot for 45 minutes.
Where are you located?
Old 01-25-2024, 09:31 PM
unruhjonny's Avatar
honestly, if you put a little bit of effort into it before worrying about the rust, your time invested will be well worth it.
Take them to a pressure washer to get the grease and oil off;
Then a soak in evaporust(ect) will prove astonishing results.
1970 Formula 400
Old 01-25-2024, 11:07 PM
I have no concept...of what anything costs anymore.....
Figured if that what the price was....I would find an alternate method...
I'm north of Seattle...about 150 miles...
Old 01-25-2024, 11:20 PM
Half-Inch Stud's Avatar
An electrolysis, lemon juice, oxalic acid, snd such may be woryh it for 3 or more manifolds.
Old 01-25-2024, 11:48 PM
I understand. It's hard to keep up with the escalating costs of everything. WA is a long way from OH! You might want to shop around some more or try one of the other methods mentioned. Hot tank won't work. Does not remove rust. If having the parts commercially cleaned, thermal is the way to go. Works great on aluminum too at a much lower temperature. We bake aluminum at around 300 degrees for 1 to 1 1/2 hours depending on the amount of sludge and carbon. Then blast. The blasting darkens the aluminum slightly, but still produces an "as cast" look.
Old 01-26-2024, 04:22 AM
lust4speed's Avatar
1967 intake manifold media blasted with #7 glass bead and an early hub/balancer assembly.
Name:	67 Intake manifold.jpg
ID:	627235   Click image for larger version
Name:	Balancer cleaning.jpg
Mick Batson
Old 01-26-2024, 04:35 AM
Drag Star Le Mans's Avatar
So you must be in Canada or just hiding your location? Nothing a trip to local machine shop and a hot tank clean up can't handle. They have always been cheap for me? Just a thought.
DragStarLeMans
