Tri-Power Tech 57-66 Tri-Power Talk
Old 06-27-2020, 09:42 AM
dhcarguy's Avatar
dhcarguy dhcarguy is online now
Default Small and Large check balls
In my 65 center carb which check ball goes where? I did not pay attn. when I took it apart to clean. I know where check balls go just not sure which is which.
Thanks, Dave
Old 06-27-2020, 10:15 AM
pfilean's Avatar
pfilean pfilean is offline
Is one aluminum and one steel? If so I think the steel goes in the pump discharge hole under the pump discharge spring and held in by the "T" shaped spring guide. The aluminum would go in the bottom of the pump plunger well under the pump return spring.
Old 06-27-2020, 10:18 AM
Big ball DOES NOT go in the bottom of the pump well.
About all I can remember
Clay
Old 06-27-2020, 10:33 AM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
And if you put it in there mistakenly, good luck in getting it out if it wedges in there.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-27-2020, 11:16 AM
dhcarguy's Avatar
[QUOTE=pfilean;6155139]Is one aluminum and one steel?
They are both steel
Old 06-27-2020, 12:14 PM
That memory is how I remember to NOT put the big ball in the pump well.
Small in pump well
Big under booster cluster
Clay
Old 06-27-2020, 12:31 PM
wbnapier wbnapier is offline
[QUOTE=dhcarguy;6155163]
They are both steel
One should be aluminum and one steel.
Aluminum goes in the accelerator pump well and the steel one in the hole below the venturi.
I have some really old rebuild kits and they are definitely aluminum and steel.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 06-27-2020, 02:46 PM
dhcarguy's Avatar
Thanks EV1
Dave
Old 06-27-2020, 05:37 PM
Dick Boneske's Avatar
If you make a mistake and put the large ball in the accelerator pump well, I have posted a method of removing it. It becomes wedged in the too-small hole and is difficult to remove, but it CAN be done.
http://forums.maxperformanceinc.com/...94#post5664594
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-27-2020, 05:53 PM
carbking's Avatar
carbking carbking is offline
Dick - I use a modified version of your method by adding a grease zert to the tapered fitting and using a grease gun. The grease will hold the ball so it doesn't hit you in the forehead
One needs to have the casting in a vise with the access plug covered when this is done.
Heat will then melt the grease, and it can be washed out successfully.
Jon.
Old 06-28-2020, 09:18 AM
Tom Vaught's Avatar
Boost Engineer
Agree with Dick B and Jon H about the locations of the check balls
In a really bad situation with the ball stuck in the pump well I have drilled a small hole from the bottom side of the fuel bowl and the drove the ball out.
Then I peaned over the zinc material of the fuel bowl so that the drilled hole was sealed again. Not a perfect fix for a 100% restoration but has worked well for several enthusiasts on a budget with no money for newer castings.
Tom V.
Old 07-01-2020, 01:46 PM
dhcarguy's Avatar
Thanks again EV1. The kit did have an aluminum smaller check ball.
