Tri-Power Tech 57-66 Tri-Power Talk
Old 07-07-2020, 03:59 PM
topfuel67 topfuel67 is offline
Default 1966 Center carb fuel inlet filter size
Is there a special brass fuel filter for the center Tripower carbs? I had a regular Rochester fuel inlet nut on my center carb, which has a much larger fuel line diameter than the special Tripower fitting to accept the small fuel line fitting. The brass fuel inlet filter fit that nut perfectly. I just got a new (repo) Tripower center fuel nut and now that brass filter that fit the wrong nut is too long for the correct Tripower nut. The Tripower fitting does not have the flare for that filter to ride in.
Or does the Tripower not use one of those?
Old 07-07-2020, 06:19 PM
Dick Boneske's Avatar
The '66 Tripower center carb does not use a filter inside the carb. There should be an AC GF-61P filter in a bracket mounted on the front carb.
You can buy all the parts at Ames or PM me.
Name:	Nancy's '64 GTO, Kaukauna Car Show, '66 Tripower 028.jpg
ID:	544481   Click image for larger version
Name:	Barry's '66 Tripower 003.jpg
ID:	544482   Click image for larger version
Name:	'66 Tripower 016.jpg
ID:	544483   Click image for larger version
Name:	'66 Tripower 002.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-07-2020, 11:26 PM
Thank you for the reply and pics. I got the fuel lines on, mostly. I used the 5/16s copper flared washers. Now I see I need 1 3/8s for the main fuel line. This is what's killing me, is there are so many little parts I need and each one takes a week to get by the time I order and ship.
Old 09-06-2020, 01:56 PM
mike w mike w is offline
Default Copper "washers" for fuel lines
I realize this reply is too late to help you in this case. However, these copper washers, used with flared fittings, should not be necessary. Especially, if using with aluminum lines and brass fittings. Both are soft, and a gentle tightening should create a good seal.
If using Stainless Steel lines, these are probably a good idea, as the lines are so hard that they can be difficult to get to seal.
Mike Wasson
