Tri-Power Tech 57-66 Tri-Power Talk
Old 07-09-2020, 08:11 PM
footjoy's Avatar
footjoy footjoy is offline
Default 65 electric choke
Where can I get an electric choke for 65 tri power?
Greg
Old 07-12-2020, 01:16 PM
mike w mike w is offline
Default electric choke insert
This part is sold on www.pontiactripower.com
Also available are electric choke conversions for the 1966 center carb.
Take a look.
Old 07-12-2020, 02:03 PM
Dick Boneske's Avatar
I've used electric chokes off Rochester carbs in junk yards. Just make sure the coil moves in the right direction as it heats. It needs to rotate clockwise as you view it from the passenger side of the carb. Some are reverse of what you need, but you can pull off the coil and install it the opposite way.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-21-2020, 01:23 PM
bill ryder's Avatar
bill ryder bill ryder is offline
I just found the one I removed from my 65. If you still need one, PM me.
"Bill"!
Old 08-04-2020, 02:41 PM
footjoy's Avatar
I got one off of quadrajet parts website
Thanks everybody
Greg
Old 08-06-2020, 01:28 PM
Most all choke assemblies from other Rochester carbs work on our '65 or earlier Tri-Powers, but you need to be careful. Some choke coils are the reverse of ours, so you need to pull off the coil and install it upside down. I found out when a Tri-Power I restored had the choke close as the engine warmed up instead of opened as it should.
It's easy to check this by heating the coil slightly and observing the direction the tab moves as the coil heats. It needs to move CCW as you look at it from the inside. Same story for electric or stock coil.
BONESTOCK GOATS
