Old 03-14-2024, 10:35 PM
Default FYI…New Moldex crank for sale on FB Marketplace
Supposed to be a new Moldex 4.500 stroke 2.200 rod journal 3.250 main. $1600 in Mansfield, OH.
Dr. Thomas Sowell
Old 03-15-2024, 06:19 AM
Years Ago Butler was having Moldex grind up from Kellogg Crank Billets THREE of those crankshafts a month. That was when people wanted 4.5 stroke, billet cranks that fit into factory 455 SD type blocks.
A good price for the crankshaft today.
Old 03-15-2024, 09:19 AM
mgarblik mgarblik is online now
That is a smoking deal for a Moldex billet crankshaft in today's market. Less than 1/2 price actually. I would strongly recommend 5 billet main caps and a very light rotating assembly if used in a stock block.
Old 03-15-2024, 09:56 AM
That’s what I thought, Mike.
Dr. Thomas Sowell
Old 03-15-2024, 01:22 PM
misterp266's Avatar
Figured I’d post the link in case anyone is interested.
Amazing price!
https://www.facebook.com/marketplace...e-2b153141d5cc
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 03-15-2024, 01:47 PM
65madgoat's Avatar
That facebook seller has a nice selling reputation it seems. Ooooofffff
Too bad not a 4.25" stroke for me...
Old 03-15-2024, 04:24 PM
Skip Fix Skip Fix is online now
Interesting it says it is a 3.25 main and 2.20 rods!
Old 03-15-2024, 05:05 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
If it was a 3” main , I’d be on it.
Old 03-15-2024, 06:17 PM
I think some of the Indian Adventures blocks were delivered with 3.25" mains. That would make a nice engine. Also a stock block 455 would be fine IMO with aluminum rods and light pistons. Probably want to keep the piston speed down a bit with that long stroke and high bearing speed. Properly built, it would be fine around 6500 RPM's. Tons of torque. Love to have that in a heavy street car.
Old 03-15-2024, 06:57 PM
Mr Twister's Avatar
Mr Twister Mr Twister is online now
I'm amused. Would one be able to cut the mains to 3.00 and fit to a 400 block? I'm not well versed on strokers.
Old 03-15-2024, 10:36 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
chinese billet? wrapper has chinese writing on it.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 03-16-2024, 08:23 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
I agree looks like a pdude chinese billet
I have one in my car it’s been great still standard standard after 20 yrs of abuse
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-16-2024, 10:26 AM
I have one of those P Dude billets in my 500" IA motor. 25 dyno pulls and a number of hard 1/4 miles. 4.21 stroke Pontiac rod journals and 3' mains. . I have another 4' stroke planning on using too. That was before we had all the forged options. Specs were right on vs some of the early forged ones that needed to be turned due to taper-lokemy 409's eagle stroker crank.
Old 03-17-2024, 08:47 AM
GTO-relic GTO-relic is offline
the piston speed is fixed to the stroke length, it can't be decreased at all with lighter parts. you'd have to destroke the crank to decrease the piston speed.
unless you meant probably want to keep the piston/rod weight down, with that high piston speed/bearing rubbing speed.
Old 03-17-2024, 10:03 AM
Yes, the comment was a little vague. I guess my point was more that the max RPM should be kept down some from what could be considered safe in an aftermarket block with 3" mains.
Old 03-17-2024, 10:43 AM
Mr Twister's Avatar
So, is the consensus that this crank is a Chinese forged unit sold by P Dude back in the day? Possibly finished by Moldex.
Old 03-17-2024, 11:20 AM
My billets from P Dude were from Ohio cranks
Old 03-17-2024, 03:37 PM
I think if someone was really interested in buying it, they would need to have a conversation with the seller about all the particulars and the history of the crankshaft. If I remember right, the Moldex cranks I have purchased from them had a job number on them and some other info stamped on a counterweight. Also, My Moldex crankshafts said 4 1/2 instead of 4.500 on them. But they certainly could have changed that. The asking price is still OK for a Chinese billet but then you have to pay someone to go through an entire QC process before use. It would need to be magnafluxed, stroke checked, thrust dimensions verified, crankpins and mains verified for size and checked for straightness. I really doubt Moldex would attach their name to a Chinese crankshaft unless it was sent to them for repair or something like that. The ad says it's never been used or in a block but obviously a balancer had been fitted to the snout at some point. The snout is scarred up some where a balancer was installed.
Old 03-17-2024, 04:22 PM
Formulas Formulas is offline
Is that double cut short keyway a source fingerprint
