Old 05-21-2019, 06:02 PM
4 lines & 2 words of space used in above to the point factual response, Jon. No speculating or purporting this or that aka BS.
Old 05-21-2019, 09:24 PM
unruhjonny's Avatar
I think this was my source;
eighth listing from the top;
curiously there is no indication of a 70-74 issued 14x6" Rally II;
I realize that using a Master Parts Catalog has it's own perils, and weather or not this application code is correct for '70 model years, just the MPC showing a listing for them would seem to indicate that there was one.
OPH's post seems to suggest this code was in fact used for 1970.
1970 Formula 400
Old 05-21-2019, 11:08 PM
unruhjonny's Avatar
this post has left me scratching my head.
(I only JUST now noticed it)
1970 Formula 400
Old 01-07-2021, 06:03 PM
ladytata's Avatar
ladytata ladytata is offline
Stock or ??? These came off a pretty original 73, any info would be great. Car was very original but can’t seem to find any info on these rims. Thanks
Old 01-07-2021, 08:08 PM
Held for Ransom's Avatar
14 x 6 standard rim. Used at least in '74, may have started in '73.
So long, farewell.
Old 01-07-2021, 08:20 PM
ladytata's Avatar
With that c EL?
Old 01-07-2021, 08:21 PM
ladytata's Avatar
These came off the car I sent you that sheet on
Old 01-07-2021, 08:56 PM
You still haven't stated what the body build date was. Or what PHS showed for a ship date. This rim was assembled by Norris Technologies (NT) or Norris Industries (NI), not Kelsey-Hayes. If you look closely, you will see other numbers stamped by the valve stem hole. C should be the month and EL, the application. A Space Saver I had was a Kelsey-Hayes assembled that was dated in Feb.
So long, farewell.
Old 01-07-2021, 08:58 PM
ladytata's Avatar
I’ll get you a body tag pic, as for build sheet it’s long gone
Old 01-07-2021, 09:02 PM
ladytata's Avatar
Old 01-08-2021, 03:40 AM
Transamric's Avatar
There's also a possibility that the stamp which appears as a 'C' was made with a damaged '0' (ZERO) stamp, therefor being part of the numbered date code.
Old 01-08-2021, 11:31 AM
ladytata's Avatar
Mike, I’m still trying to guess what these rims are, my pic might of not been the best, there is nothing before that C, no T no m1/3, just that C and the El. I’ll probably have to take the tire off.
Old 01-08-2021, 04:59 PM
Look at the pics Jonny posted here...
http://www.forums.maxperformanceinc....d.php?t=829749
There are other numbers stamped.
So long, farewell.
