Old 01-18-2021, 06:51 PM
grd777 grd777 is offline
Default need advice on my a/c , heater control
i am missing the metal part the goes on the the vac port . can i cut the rubber one in the photo and just attach to each one
or does anyone have one for sale
Name:	IMG_4252 (002).jpg
Old 01-18-2021, 09:18 PM
ladytata's Avatar
ladytata ladytata is offline
I might have a junky unit for parts
Old 01-18-2021, 10:58 PM
ok let me know
Old 01-20-2021, 07:38 PM
anyone out there that can give me advice or should i just the one i have and try to make it work
Old 01-20-2021, 09:16 PM
ladytata's Avatar
Sorry for late reply, I looked for my junk one, must of sold it. I do have a few whole ones if worse comes to worse
Old 01-21-2021, 09:56 PM
i guess i will cut it and let all know how i make out
Old 01-24-2021, 03:52 PM
the rubber part you see in this photo is from a 79-80 t/a . what i am looking for one that will work on my 72 firebird one , anyone have a photo of one . my last resort would be to cut each one of these and install theme on each port
Old 01-29-2021, 07:21 PM
ladytata's Avatar
Old 01-29-2021, 07:33 PM
Ok how much for that
Old 01-29-2021, 08:47 PM
ladytata's Avatar
Not cheap, I was just trying to help you out with a pic
Old 01-29-2021, 11:27 PM
It'd be rough but if you had a template for the holes, you can use a round rubber block and drill holes in it. Something like a hose clamp around it with angle brackets for retainer tabs. It just needs to be snug and mostly seal. A thick sheet of rubber would be similar, enough to stick vacuum lines into and be tight, dab of silicone maybe to hold and seal. Easy to pull off in future when you find part.
Old 01-30-2021, 02:01 PM
Formulabruce's Avatar
This rubber connector came as part of the vacuum harness for AC. The hoses were glued into the connector. You should just buy a uncut vacuum harness for 71-75
Old 01-31-2021, 09:02 AM
I cut up the rubber on in my photo and used the round pieces and connected to the vac ports
Still like to buy one if if comes up for sale
Old 01-31-2021, 09:03 AM
Ok thanks for the photo let me know if one comes up for sale
Old 02-05-2021, 05:19 PM
unruhjonny's Avatar
here are some leads for you:
https://www.lectriclimited.com/air-c...harness-118775
https://www.secondgengraveyard.com/
http://www.spottsperformance.com/fbharness.htm
https://www.ebay.com/itm/402457790685
good luck!!
1970 Formula 400
Old 03-05-2021, 09:56 AM
ladytata's Avatar
Found it
Old 03-05-2021, 09:57 AM
ladytata's Avatar
Got this too
Old 03-05-2021, 10:49 AM
78w72 78w72 is offline
pretty sure i have one of the black rubber vac line fittings if you still need it... & for a reasonable price.
Old 03-05-2021, 04:32 PM
Got this too
How much for the bracket set up
Old 03-05-2021, 04:41 PM
indymanjoe's Avatar
if anyone knows if a 70-72 Lemans rubber piece would work i'll send it.
