Old 04-03-2008, 07:57 AM
Keith Seymore's Avatar
Last one for now. This one could get long but I'll try and be as brief as possible.
Before Dad started racing Pontiacs he was racing Ford products. He had a '60 Ford convertible with a Paxton blower on it that ran pretty well.
As a result, he had a good working relationship with Ford and was even trying to get hooked up with a factory lightweight in late '62/early'63. That didn't happen and is another story for another day...
Tom V might correct me here, because I often see a different name for Ford Racing at the time, but I believe Dad's contact at Ford was a gentleman named Dave Evans. Dave called Dad one day, out of the blue, and said "come on down here; I've got something for you".
Dad got the details. He was supposed to go over to Dearborn Steel Tube and pick up a box. He drove over and they directed him out back to see "Andy". Andy told him "...put this in the trunk of your car and don't open it until you get home".
Naturally, Dad pulled out of the parking lot and into the very first Shell station he saw and opened the box. In it was a complete 3x2 setup for a Ford; everything required for the installation was there. Intake, carbs, air cleaners, fuel lines, gaskets, everything.
After he got home, Dad called Dave and asked "what am I supposed to do with this thing?". Dave said "make it run. We can't get 'em to run...".
After a day or so Dad had the setup installed and tuned and took it out for a trial run. Sure enough, as soon as he went wide open the engine flooded out and stalled. He tried it a couple more times with similar results. He drove the car home, took everything apart, inspected and readjusted everything, reassembled it but still had the same results.
After thinking about for another day, he called a buddy over that was racing a Ford with twin Paxton blowers on it (Brad Burton was his name). They took the car for a ride, same results, and disassembled the setup for inspection. Brad left and Dad went to work that evening, came home and went to bed.
About four am the phone rang. It was Brad. He said "I know what it is! Meet me in the garage!". Dad drug his sleepy self out of bed and went to the garage. They took the carbs apart for the hundredth time and Brad said "AHA! There it is....I knew I noticed something wrong before but couldn't put my finger on it". What he had seen was that Holley had put power valves in the end carbs, allowing too much fuel to flood the engine. "We've got to plug those off".
So that night, in the Chevrolet die room, Dad made his first set of homemade Holley power valve plugs for use in a Ford Tripower!
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
  #42
Old 04-03-2008, 07:58 AM
Just to finish the story:
After installing the aforementioned plugs and creating a "progressive" linkage, Dad's car was running like a scalded dog. He called Dave Evans.
"How's your cars running?" he teased.
They aren't, Dave replied.
"Mine is" Dad said. Dave told him to get down to the Engineering building immediately.
Dad drove down later that morning, honked the horn at those beautiful wrought iron gates next to Greenfield Village and was allowed entrance onto the Ford facility. Dave met him down by the street and said "Ok. Show me". Dad said "right here?". Dave nodded affirmatively so....Dad backed up and smoked his Atlas Bucrons the whole length of the parking lot. "Wait here" Dave told him. He ran upstairs and brought the respective Engineers down to the street. Dad did it again and then delighted in showing them the changes he had made to their induction system, while another set of Engineers crawled under the car looking at his suspension modifications and still another couple were looking at his shifter and shift linkage.
All in all, a good day...then he would scurry back north to get home in time to work 2nd shift at Chevrolet.
'63 Grand Prix
  #43
Old 04-03-2008, 09:52 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Those are great stories, Keith - keep 'em coming!
My great-grandfather started at Chevy in Flint when it was a relatively new company - probably in the teens or early 20s. He got his son (my grandfather) a summer job there during college in the late 20s-early 30s, during the depression, and during the UAW organization of the plant. (He has some not-very-complimentary stories of the UAW from those days.) My great aunt started at Pontiac in 1929, worked somewhere else within GM during the war when everything was consolidated, and then continued on with Oldsmobile in Lansing until she retired in 1974.
Various other aunts and uncles make up the remainder of the 300 or so years of GM experience in my family. Lotsa stories among them, too.
Mike
  #44
Old 04-03-2008, 11:00 AM
One of the things Dad used to do was make special parts for "the Father of the Corvette", Zora Arkus-Duntov. If Zora had something unique, like an air cleaner or special oil pan or something, he would call up to Flint Manufacturing (since that was where the base part was made) and ask for the die room to whip it up. He would ask for Dad, specifically, to make the parts for him ("...I van da skeeny diemaker to make deese..").
One time Zora was doing a study on valvetrain geometry on small block Chevies, so he requested (via a sketch on a napkin) a batch of rocker arms to be made in various ratios: I think they started as low as 1.2:1, then incrementing up through 1.50, maybe 1.55, 1.60 and finishing up with a 1.65:1 ratio. He asked for 100 pcs of each, so Dad would run 100 for Zora, and then 100 for himself (and stick them in his locker).
I have mentioned before a couple brothers here in Michigan, Dave and Ben Wenzel, who were doing very well running a Camaro in the NHRA stock and modified classes. They are/were national record holders, multiple time class winners, etc. Dad happened to see them up at Tri City one time, so he handed them a bag of these 1.65 ratio rocker arms and said "here, try these".
They looked at him like "...who are you and what are these and why should I try them?".
Dad said "...just try them".
They did, and then they were REALLY flying. They got protested, torn down and the cam checked but were declared legal. Nobody ever did notice these special, production looking rocker arms that they were running.
'63 Grand Prix
  #45
Old 04-03-2008, 02:53 PM
As an aside, this was far from our first experience getting torn down...
Dad and the Ramchargers went 'round and 'round on more than one occasion. One of his favorite stories was how, after beating their B/S automatic Dart for Stock Eliminator, they protested and made him tear apart the engine for inspection. He told Jim Thornton "I'll tell you everywhere I'm not stock if you'll do the same", especially since he knew he was "more legal" than the Ramchargers were. Thornton refused and actually set the cam up in "V" blocks and a degree wheel on the tailgate of their MOPAR station wagon and, using a dial indicator, (begrudgingly) found it to be legit.
The cam was actually bogus as h*ll; it was a special grind done by Mac McKellar, but with stock lift and duration (and the stock numbers stamped on the end).
Dad towed home with half the motor in the trunk, an extra $100 in his pocket and a smile on his face...
'63 Grand Prix
  #46
Old 04-03-2008, 05:11 PM
A-body A-body is offline
I really enjoy reading these stories. Because not everyone frequents the 66/67 section, would it be feasible to move this thread to the Lobby, so others can enjoy also?
  #47
Old 04-03-2008, 06:00 PM
What a great idea fop a book. Putting all this info together in full length. I enjoy the the production stories. Not so much the office or design staff stuff.
  #48
Old 04-03-2008, 06:44 PM
patox's Avatar
patox patox is offline
Send a message via MSN to patox
Keith, have you ever posted more stories like this?, I will really like to search them in order to read them all!!, I have had a wonderfull time reading your anecdotes....
If you decide to write a book, I'll bought you the first copy!! (remember it if you do so!!)
Keep them coming!
  #49
Old 04-03-2008, 08:52 PM
Andre's Avatar
Andre Andre is offline
This beats Wangers book with a stick... you could sell him these stories so he could use them as his own
  #50
Old 04-03-2008, 10:20 PM
GT182's Avatar
GT182 GT182 is offline
Great stories Keith, please keep em coming. BTW, put me down to buy the second copy of that book when it's finished.... autographed too.
I've never heard of a Holley 950CFM 3Bbl that's in the Wenzel article. What's the story with them?
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #51
Old 04-04-2008, 08:04 AM
Keep them coming!
Thanks, gentlemen...
I appreciate the encouragement.
I'm not sure there's enough for a book; maybe just a chapter in someone else's book!
I do have some more coming (I'm waiting for my secretary to unlock the file cabinet with the scanner in it...). For now, here are a few of my favorites:
Finding and interpreting historical documents: http://forums.maxperformanceinc.com/...d.php?t=549092
A few tidbits during the trivia game: http://forums.maxperformanceinc.com/...d.php?t=547027
Some discussion on assembly processes: http://forums.maxperformanceinc.com/...d.php?t=495766
A couple Arnie Beswick stories: http://forums.maxperformanceinc.com/...=546939&page=3
Delorean and "the Sandwich": http://forums.maxperformanceinc.com/...d.php?t=549318
'63 Nationals: http://forums.maxperformanceinc.com/...d.php?t=549309
Old racer pics: http://forums.maxperformanceinc.com/...d.php?t=543741
'63 Grand Prix
  #52
Old 04-04-2008, 08:12 AM
I do have some Wangers stories, but I have been hesitant to write them down out of respect for his legacy (...and just in case we remember them differently ).
I'll share one in the next batch.
Yep - it's fer real. I think I have some pictures of one in a Holley book; I'll post when I can get to the scanner
K
'63 Grand Prix
  #53
Old 04-04-2008, 03:01 PM
copied this to the lobby per keith's request.
mike
former." --Albert Einstein
- Winston Churchill
  #54
Old 04-04-2008, 04:38 PM
Originally Posted by mzbk2l
Oh, and for some of you guys who don't believe the things that are tucked away, you probably would have cried if you'd seen the dumpster-loads of new old parts that were thrown away when the warehouses were "purged" after the 2000 announcement that the DPG would be closed.
Not many Pontiac-specific parts (unless you count pallets of brand-new blue-anodized 30th Anniversary T/A wheels, GTP wheels, supercharged 3800s, etc.), but lots of brand new BBC stuff, including blocks, aluminum heads, and complete engines.
It all had to go to make room to rent out space to Indian motorcycles (and now to H-D), and to sell off 1/3 of the acreage.
Logic of Empire.
  #55
Old 04-04-2008, 05:39 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Great thread, keep it going!
Regards,
"455HO" Lloyd
  #56
Old 04-04-2008, 06:06 PM
Tom Vaught's Avatar
Boost Engineer
1) Yes, Keith, Dave Evans would have been one of the higher up Ford Engineering guys in that time period.
So your Dad had a blown 1960 Ford Convertible (with a Paxton Supercharger on it). Cool. I am surprised that the GM UAW would have allowed a Ford Vehicle in the GM Hourly parking lot during that time period on 2nd shift.
Blower cars typically need "solid floats" to survive boost. The "black floats" we have today were not around then. The side hung bowls (no race bowls in those days) had pretty strong waffle sided floats which may have been ok for your Dad's low boost paxton deal. If the guy helping your dad, jetted up the carbs pretty good, I could see where the extra fuel from the extra power valve circuits could have caused the issue you mention, even with the blower. Same deal with the progressive linkage.
There is a nice web site that deals with Ford Tri-Power systems here: http://www.gerlecreek.com/documents/tptechnical.htm
Read through the info and maybe you will recognize a few more names.
A Pic of the prograssive linkage is shown in the 61-63 Ford & Thunderbird 6V Accelerator Linkage and Related Parts topic.
Tom V.
  #57
Old 04-05-2008, 12:24 AM
citydesk175's Avatar
citydesk175 citydesk175 is offline
A couple of quick stories from the old PMD Engineering days.
1. My boss used to brag about putting together the 64 GTO parts list and other engineering / specification documents that actually told the assembly plants how to put those first GTO's together. In retrospect, I should have pressed him for more historical details. But there are two schools of thought: Either the participants involved in the design, engineering and manufacturing of a classic car performed a special act of magic OR they were just doing their jobs and deserve no extra credit or personal recognition.
2. This same supervisor was driving a company car through the Pontiac site carwash when his passenger brain-farted and pressed the button on the sun roof. Now there was an opportunity to tell a creative story to management.
3. In the trying days before drawing copiers and CAD, Original drawings were drawn on vellum or mylar by hand and then contact printed on Diazo (developed by ammonia) paper for distribution to the plants etc. My boss had a crew of "blueprint" machine operator who among other duties replenished the ammonia supply at the machines.
They took the empty ammonia carboy to the first floor and refilled it safely but one day when they brought it up to the second floor, they spilled it down the elevator shaft. The mechanics, lab workers etc were all sent home with pay because of the health "risk" of ammonia.
4. One of the Pontiac draftsmen made drafting tools & instruments in his basement shop for his peers. When he died, his boss was the first to talk to the widow and she sold him the power machinery (lathes, mills etc) the hand tools and pecision tools as well as thousands of dollars worth of nickel silver raw stock for like a thousand bucks.
5. The draftsmen worked a load of overtime drawing lines that became your fave cars. It is widely suspected that some of those draftsmen kept their wives updated on the extra cash flow. But many insisted that Salary meant just that: Salary and they got no extra pay for working six ten's each week. One draftsman's logic was "she has no room to complain, she gets one new dress a year. What more can she want?"
KTF
more to come
and thanks to Keith et al
  #58
Old 04-05-2008, 01:20 AM
sdbob sdbob is offline
That picture of the Corvette.The hood looks like a raised big block model.With emblems along the flanks.Possibly 427? L88?
I enjoy the stories something about stories that you remember the good times.
A Pontiac story.About 1977 I was at Keystone Raceway ne New Alexandria,Pa. I noticed a 63 catalina in the staging lanes.Glanced under the car and noticed the perforated frame!later found the car to be the Royal car, then the owner had the hood open-RAV dual quads.Got talking to him,Jim Phillipps from Canonsburg area.His father owned Equipco.Anyways went to his shop and saw the original 63 SD engine.He related this story about the RA V.He was a I think a zone rep for Pontiac.he heard they were going to destroy a lot of racing parts.he went to the actual crush site and was literally throwing RA V parts out of the crusher. Could this have been true? or bul.
  #59
Old 04-06-2008, 04:24 PM
Thanks, Tom. Nice link.
I did see at least one name I recognized...
'63 Grand Prix
  #60
Old 04-07-2008, 02:57 PM
Default PLANT CARS
Is it possible that some cars are kept at Assembly plants beyond the time they should have been sold as mileage cars to employees or as surplus or scrap.
There was a time that certain cars were matched to drivers as a 5 year durability car but no one has mentioned it around here.
It would seem that certain cars might have been built unofficially and get retained as "Plateless" plant property only cars and never show up on the inventory or show up lightly. I can picture the cars being used for errands and deliveries.
Some one just mentioned a car of this type at Wilmington that might have been a hidden classic but probably was not.
I know there is a natural tendency in some plant managers to scrap strange cars at the drop of a hat to keep embarrassement at a minimum.
Take care
