Old 04-19-2016, 09:02 AM
THEGTOCHISM's Avatar
THEGTOCHISM THEGTOCHISM is offline
Question G BODY AC heater controls
working on the wife's 84 g-body. I replaces ac compressor ,dryer, orifice tube, flushed everything, new seals, pulled it down real low for 1 hr. added the r 135 change and it cooled great! for a week . Problem is now it blows only hot air out the ac ducts on max. hooked up the gauges everything looks great. i am thinking heater hot air door stuck open. . or cable related. Temps here have been swinging from heat to ac, where i live so i have moved the controls a few times. anyone got a idea or picture of the duck works?. is it cable controlled? i see it has a lot of small vacuum lines in the engine compartment .going inside the cab.
70orbitorange
Old 04-19-2016, 10:35 AM
HO 67 BIRD's Avatar
HO 67 BIRD HO 67 BIRD is offline
http://www.gbodyparts.com/product_in...roducts_id=409
This might be the problem. if you pull the glove box door down you will be able to see the plastic pc above or the cable clip that attaches to the side of the hvac box has broken.
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER
2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER
Old 11-18-2017, 11:48 PM
LeoP's Avatar
LeoP LeoP is offline
check this out, www.montecarloss.com/SS_FAQ_16.html#4 and good luck!
Old 11-19-2017, 06:19 PM
Jack P. Jack P. is offline
The controls are vacuum operated. These need to be connected correctly to work. Also if your A/C compressor is not energizing there is a relay that you need to verify is being powered up.
Old 12-10-2017, 12:36 AM
LeoP's Avatar
AFAIK, the temp door is cable operated.
