Old 04-26-2017, 10:27 AM
BobC BobC is offline
Default Butchered Bird
Another project followed me home on the trailer. 1972 base Firebird stick car. It has no interesting pedigree or history. It's only claim to fame (other than being a 1970-1973) is the body is in good condition. The elephant flares are riveted on fiberglass tubs with lots of bondo. Luckily the quarters were not hacked!
ID:	453103   Click image for larger version
Old 04-26-2017, 10:32 AM
Tried posting on my phone for the first time. Pictures are rotated 90 degrees? Any help to prevent this would be appreciated.
These strange looking parts were in the trunk. What could they be for?
Old 04-26-2017, 10:38 AM
They're the exhaust manifold shrouds.
The turned pics in my opinion is the phone camera makes the pic with a set 'direction' and when looked at on PY (and probably others) they get the dimensions/directions wrong.
(did you take the pics with the phone sideways?)
Basically you can't rotate the monitor like on a phone.
Old 04-26-2017, 10:49 AM
Good to see you saved it, Bob, what are the plans?
If the flares were here, they would be "filed" into the appropriate container relatively quickly reminds me of a '70 GTO factory 4554spd car, a good friend & I went in together in the mid 90's. Very similar distasteful body mods, even the front fenders were flared using a base structure of welding rod. parts in the trunk... the seller must have had a '71 HO car or engine @ some time.
Old 04-26-2017, 10:59 AM
As of now plans are for a TA clone. Not sure on the drivetrain. It could be classic Pontiac or LS3/TR6060. 17" Rally II repop wheels and lowered a bit. I'm going to be part shopping.
There just may be a little surprise under that beat up Formula hood!
Old 04-26-2017, 11:02 AM
Judge273's Avatar
Judge273 Judge273 is offline
The top 2 are mounted on intake of a HO on passenger side. The bottom 2 on drivers side exhaust manifold. Inner and outer. You will see them in Ames...
Mike/Illinois
Old 04-26-2017, 11:50 AM
bird72's Avatar
bird72 bird72 is offline
A solid 70-73 factory clutch car is a great find and awesome build platform. Cool!
72 Bird
Old 04-26-2017, 12:40 PM
It was advertised as an automatic. When I went to check it out I saw the 3rd pedal. While under the car I saw the factory cut hole for the shifter and the subframe mounted bracket for the z-bar. The owner had no idea.
Old 04-26-2017, 01:14 PM
njsteve's Avatar
njsteve njsteve is offline
Those are the vintage Trans Am and IROC Camaro series flares from back in the mid 1970's. Neat vintage flares if you can somehow save them. They could be worth some $$$ to someone restoring one of the old race cars.
Old 04-26-2017, 01:45 PM
WOW, great find for that information and thanks much for the photo. There's a LOT of bondo over the fiberglass flare. Don't know if the flare can extricated without damage. They are being removed from the car though. If someone wants to come to my place and try to remove them in one piece they're sure welcome! I'm in the Kansas City metro area.😁
Old 04-26-2017, 07:10 PM
bird72's Avatar
What of the notion of doing the front flares also and do the IROC look? Fat tires..... Outlandish color scheme, graphics, stripes, have fun... numbers on the doors!
72 Bird
Old 04-26-2017, 09:10 PM
Finally got around to taking some engine photos. This may explain the sheet metal
parts in the trunk.😁
ID:	453141   Click image for larger version
ID:	453142   Click image for larger version
ID:	453143   Click image for larger version
Old 04-26-2017, 09:19 PM
cnc's Avatar
cnc cnc is offline
Is that an HO Intake I see!!!!!
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 04-26-2017, 09:40 PM
Also block, heads and carb. Haven't checked the dist. yet. YE code 1971 455 HO installed at some time in the distant past along with the '70 12-bolt.
Old 04-27-2017, 05:58 AM
Judge273's Avatar
Nice transplant! Not sure what's going on with fuel line?
Nice 71 TA Auto engine to have included in a rust free body. Most likely if rear is 12 bolt from 70 hope it's a COZ would be a bonus..
Mike/Illinois
Old 04-27-2017, 07:36 AM
There's a reason I named this thread butchered bird. Everything that was touched on this car was hacked or half a$$. The body is not rust free but all of the important places are solid. Since this is the tech section I'll post some pics showing what not to do.
Old 04-27-2017, 08:07 AM
BertMac's Avatar
BertMac BertMac is offline
Blue Springs??? thats where I went to High School..graduated in 1979..
I have the Trans Am fender scoops for that car if you are interested, I was going to put them on my formula but changed my mind.
Bert
65 Mutant
1967 Firebird Fatass
70 Mutant II
I want my driveway to look like I'm stuck in the 70's!!!!
Old 04-27-2017, 03:34 PM
marxjunk marxjunk is offline
neat car...for sure
it seems the turned pic thing is a code read thing..i've figured out by doing a google, if you turn the phone sideways they button needs to be to the right before ya click or it will be upside down..i tried it..and it fixed it for me..i dunno if its good advice or not.....
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 04-27-2017, 05:56 PM
The Boss's Avatar
The Boss The Boss is offline
I like it - nice grab!
Fixed the pictures for you - they deserve to be bigger.
ID:	453234   Click image for larger version
And go racin' in the street.
Old 04-27-2017, 06:06 PM
unruhjonny's Avatar
OH man!!!
That right there is a MAJOR score!!
Congrats!
1970 Formula 400
