Old 07-27-2019, 07:04 AM
chrisp chrisp is offline
Default Z-bar/ clutch pedal repair bushings
Z-bar/ clutch pedal repair bushings these flange bushings repair the wearable egg shaped holes / you will need to weld your male ends & then file fit these to fit . The elongated holes would need to drilled to 3/8" to accept the repair bushing , check both holes on zbar & the clutch pedal hole as well . Welding is only required to fix the male ends on the zbar linkage from the pedal to zbar ends & clutch adjustment rod end . Also makes a nice smooth pedal / non binding . $30.00 for 3 pcs. as per required .
Old 08-19-2019, 05:59 PM
Available.
Old 10-05-2019, 06:47 AM
In stock.
Old 10-19-2019, 06:26 AM
Bump
Old 12-05-2019, 08:06 AM
A few sets left.
Old 12-29-2020, 06:47 PM
6d7gto 6d7gto is offline
Originally Posted by chrisp View Post
A few sets left.
Hi. Do you still have these available?
Robert
Old 01-04-2021, 12:41 PM
Bushings are back in stock.
Old 01-05-2021, 08:55 AM
If the male ends are good then no welding is needed .
Old 01-16-2021, 08:36 AM
Bump
Old 02-27-2021, 09:05 AM
Fits 5/16 [0.3125] ends only set of 3 $30.00 shipped USPS with tracking & delivery confirmation.
