Old 08-21-2019, 11:44 PM
einstein's Avatar
einstein einstein is offline
Default Early 1969 ZH or ZG nodular rear axle unit
Date code October or November 1968. Prefer the cast numbers be readable and the housing not be badly rust pitted. May consider just a housing, as I have a 3.55 chunk.
Would also consider ZG 3.36 complete.
Old 08-22-2019, 12:14 AM
Ram4king's Avatar
Ram4king Ram4king is offline
ZG will not be Nodular
Old 08-24-2019, 11:23 PM
FASTASSBIRD FASTASSBIRD is offline
I think I have a complete 3.36 Nodular
Old 08-24-2019, 11:31 PM
False alarm. It’s a ZF
Old 08-26-2019, 09:00 PM
einstein's Avatar
ZF = 3.23 posi? Date code meet my criteria?
Old 08-30-2019, 01:23 AM
Little late for you at 342th day. Think it’s a 3.31?
Old 09-02-2019, 02:48 PM
einstein's Avatar
So close on date, my car was assembled Dec 17. I confirmed the ZF is 3.23. Day 342 is what, Dec 8th
Old 09-04-2019, 12:19 AM
Dec 7th according to Epochconverter.com
Old 02-25-2020, 05:27 PM
einstein's Avatar
Still need a ZH dated Oct/Nov 68. Would consider first week of December, car assembled 12/17/1968.
Added a wanted post in the OHC/Sprint forum, as a 69 Sprint parts car would have been factory equipped with ZH.
Old 02-26-2020, 08:31 PM
My old 1970 trans am had the original rear end in it, and it was built only 7 days before the car. It was the closest date code on the car.
Old 01-20-2021, 12:14 PM
einstein's Avatar
Overdue bump! Still in want...
Old 02-05-2021, 02:59 AM
poncho4284spd poncho4284spd is offline
https://firstgenfirebird.org/forums/...124#Post310124
ZH and ZG
Old 02-05-2021, 07:19 PM
einstein's Avatar
Originally Posted by poncho4284spd View Post
Thanks, Poncho. Any idea where he's located? Been years (20?) since I was on Geoff's site. I might not be able to get logged in until after the weekend.
If you have access to contact info, can you send to me in PM?
Old 02-09-2021, 09:27 PM
I might be able to help you out if you wanna give me a call at 716-536-2047 matt you can call anytime
Old 09-09-2023, 03:51 PM
einstein's Avatar
Another bump, would still like to find this unicorn. I found some old posts referencing p/n 9795107 as the casting number.
Old 09-09-2023, 06:19 PM
Cammer-6 Cammer-6 is offline
Its always been my understanding that a 4 pinion with safe-t-track would be Nodular.
Isnt that true?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-10-2023, 03:02 PM
einstein's Avatar
If you do a quick search on the word "nodular" a couple dozen posts come up, going back ~15 years or so. Lots of good info for both A and F cars.
Old 09-10-2023, 03:10 PM
AG's Avatar
AG AG is offline
Isnt that true?
Rears were only nodular if the HD Saf-T-Trac option was ordered.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 09-10-2023, 05:49 PM
turbo69bird's Avatar
3020 was the number before the 5107 I forget when the change over happened.
960 HP @ 11 psi, 9.70 at 146.
Old 09-10-2023, 05:53 PM
I believe that 4 pinion were also only if HD was checked so what he’s saying seems. Correct to me
