Old 10-05-2020, 09:37 PM
importsmasher's Avatar
importsmasher importsmasher is offline
Default 1936 Pontiac
I just picked up this 36 Pontiac. Being a GTO/Firebird guy, I know very little about these early cars. Can anyone decode the trim tag for me? And where is the VIN tag on this thing?
Thanks,
Importsmasher
ID:	550943   Click image for larger version
ID:	550944   Click image for larger version
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 10-06-2020, 09:05 AM
moneypit's Avatar
moneypit moneypit is offline
Cool ride or sure!! I believe the model # indicates a 36 2dr 6cyl touring sedan.
The vin should be on the top of the drivers side frame rail at the firewall.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
77 Grand Prix base model, 350 pontiac
97 F250 7.3 turbo diesel
85 CJ7 Laredo
65 Impala SS 396, 4 spd, A/C.
Old 10-06-2020, 02:46 PM
Thank you! I found the VIN, exactly where you said it would be.
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
Old 11-10-2020, 10:28 PM
John V. John V. is offline
Very cool! Don't know much but google tells me the 2611 was the Deluxe 6 cyl 2 dr. Touring Sedan, 2611A was the Master.
The lower end 6 was the Master. The Deluxe had knee action independent front suspension vs. the solid front axle on the Master series.
The Deluxe had translucent dash knobs, black bakelite on the Master among other Deluxe "upgrades",
The Paint Code 16 is Black. Pontiac had 14 other standard colors in 1936, not sure if they were added cost but Black seems to have been all the rage during the Depression!
Trim Code 30 was Taupe Plush.
Found this which has a lot of extra info.
http://www.badgoat.net/Early%20Times...k%20Feb_06.htm
So what's the plan??!!
Old 11-11-2020, 07:17 AM
John,
Thanks for the info. Mine is the Deluxe 6.
Plans for the moment are to repair the wood framing in the doors (or rebuild with steel) so they're functional, then try to get it running. If the original engine runs ok, I'll leave it stock and drive it as it is while I slowly fix the body. If the original engine is junk, I'll drop in one of the Pontiac V8s I have laying around. I do plan on keeping the body original.
Importsmasher
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
