Old 11-30-2020, 01:46 PM
musclecarman15 musclecarman15 is offline
Default picture of correct bolt on 74 TA front fender flare
need help...what does the bolt and head marking that attaches the front fender flare to the lower spoiler(under facia) look like ...i know it uses a nut and 2 washers, need head marking and size....thx keith
Old 12-02-2020, 10:17 AM
78w72 78w72 is offline
my 78 & all later 2nd gens ive seen use a bolt with 1 washer into a "speed clip" on the valance, not a real nut or 2 washers.
my car is stored away for the winter right now but im sure someone can get you a pic. i replied to your wanted ad & probably have the bolts if you or someone can post a pic to be sure what you need.
Old 12-02-2020, 11:47 AM
74 models use a bolt,2 washers,and a seperate regular nut.....i understand 74 and 5 are identical ,dont know about other years, need a picture of head marking (if any) on bolt and dimensions on all hardware. thx keith
The Following User Says Thank You to musclecarman15 For This Useful Post:
Old 12-02-2020, 02:23 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
here are the bolts on my June '74 built T/A from each end of the spoiler to front flair. Since they have the same type bolt head, 1/2" size and markings, I tend to believe there is a good chance they are original but maybe someone else will chime in on theirs being the same or different. Edit, after looking at the passenger side bolt from the top it has a speed clip on it so I'm not seeing a separate bolt. Car was painted once or maybe twice in it's life so no telling if this bolt and clip went in that spot originally
ID:	555233   Click image for larger version
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 12-03-2020, 11:42 AM
thank you,would love to see an untouched car,thx again
