Old 12-19-2020, 06:10 PM
6d7gto 6d7gto is offline
Default Grease fitting thread size for countershaft Z bar
What size grease fitting does the 1967 GTO 4 speed countershaft use? The hole is definitely 3/8" diameter but not sure which thread size to use. Is it tapered or straight? Any help is appreciated.
Old 12-21-2020, 04:15 AM
lust4speed's Avatar
Talking about the Z-bar? I only have the one in my car and memory isn't good enough to remember when I welded up the original and made another to clear the Doug's header tube. If it looks like 3/8" diameter then it is a 1/8" NPT thread. If out of the car, a 1/8" pipe nipple should screw into the hole.
Mick Batson
Old 12-24-2020, 01:31 AM
Yes, Z bar...and it is out of the car. I believe you're right about it being pipe thread. A 3/8 x 24 screw fits but is sloppy. Thanks for your input. Bet you are correct in it being 1/8" pipe size which is tapered at 27 threads per inch.
Thanks again. Merry Christmas!
Robert
Old 12-29-2020, 12:43 AM
Got a 1/8"-27 NPT grease fitting today and it fits perfectly. Thanks Mick!
Robert
Thread Tools
Display Modes
