A/c harness
Can’t remember what year I took this off of. Note the 30 amp fuse. Any help would be great.
Sent from my iPhone using Tapatalk |
You might be able to identify it on the lectric limited site , they have pics of most of the harnesses they sell. My 1972 TA harness does not have that 30a fuse.
The Following User Says Thank You to tcom For This Useful Post: | ||
1973 definitely used the 30A fuse. My 1977 uses a fusible link.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
The Following User Says Thank You to 77 Canamman For This Useful Post: | ||
I don't recall my 73 having that 30 amp fuse there, mine is right behind the alternator on the 2 cavity plug, if I recall correctly.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
I’m thinking this is from a 75, I found one pic that shows a fuse
My Buddies 74 Formula 400 has that same fuse set up.
It's for the HI speed blower relay. Typically that relay shorts and this fuse gets cooked and melts the housing because its always on once the relay goes bad and shorts in the on position. Yours looks in fine shape. |
