Old 01-03-2021, 06:50 PM
grd777 grd777 is offline
Default having trouble installing my firewall carpet guard
can not get to fit ,it seems that the speedo cable is in the way . i thought i installed the speedo cable in the right place . any thoughts on this
Name:	IMG_4233 (002).jpg
Old 01-05-2021, 04:43 PM
is the speedo cable in the right hole ?
Old 01-05-2021, 05:41 PM
imposter's Avatar
imposter imposter is offline
Uh Oh Whoops
Old 01-05-2021, 11:11 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
That's the right hole for the firebird speedo cable. But it looks like your cable is not hugging the firewall like it should. You probably need to pull some slack up into the cab, it will just slide on the grommet.
I built it one piece at a time and it cost me more than a dime.
Old 01-06-2021, 07:56 AM
Aus78Formula Aus78Formula is offline
x2 was going to say you may need to pull it through the retainer on the chassis more, or use a longer cable if needed.
Old 01-07-2021, 12:25 AM
not sure if that will work it seems to be to high will try and take more photos
Old 01-25-2021, 09:19 PM
just a thought . does the speedo cable go behind the carpet guard
Old 01-25-2021, 10:08 PM
fbody_mike's Avatar
Yes, the speedo cable is supposed to be sandwiched between the plastic guard and the firewall. There should be a relief on the guard that adds room and cradles the cable.
Old 01-25-2021, 10:42 PM
thanks thats what i thought
