Z-bar/ clutch pedal repair bushings
Z-bar/ clutch pedal repair bushings these oilite flange bushings repair the wearable egg shaped holes . The elongated holes would need to drilled to 3/8" to accept the repair bushing , check both holes on z-bar & the clutch pedal hole as well . Welding is only required to fix the male ends on the z-bar linkage from the pedal to z-bar ends & clutch adjustment rod end if worn then file fitted to accept bushing . Also makes a nice smooth pedal / non binding . $30.00 shipped for 3 pcs. as per required . These fit 5/16 male ends . If the male ends are good then no welding is needed .
Reason: add
