Old 01-10-2021, 04:06 PM
pilot737 pilot737 is offline
Default 67 GTO carburetor choke issues
I don't believe my carb choke is working correctly. When I cold start the car, it doesn't go to fast idle. I removed the air filter to get a better look and most times this piece (shown in pictures) is caught on the piece next to it.
It seems there's too much 'play' ...or movement from side-to-side of the arm, allowing it to catch on the other piece. Maybe a clip is missing?
I thought on cold days, I'm supposed to press and release the accelerator to the floor before cranking?... to set the choke?
Picture 1 shows it caught on top. Picture 2 shows it in the correct position.
Name:	gto carb choke 1.jpg
ID:	558086   Click image for larger version
Name:	gto carb choke 2.jpg
Old 01-10-2021, 05:46 PM
Kenth's Avatar
Kenth Kenth is offline
Yup, clip is missing.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-10-2021, 06:32 PM
geeteeohguy's Avatar
X2. Install the clip. The correct cold start is as you are doing: once or twice to the floor and then crank with foot off the pedal.
Jeff
Old 01-10-2021, 07:44 PM
Default clip
What does the clip look like?
Or even better, a part number?
Old 01-11-2021, 05:54 AM
Kenth's Avatar
Same clip as on the choke pull-off rod, #7005109.
You may also use #836159 on these rods as a replacement.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-11-2021, 07:36 AM
Jeff Hamlin's Avatar
Thumbs up
If you can't secure one locally these guys should have what you need;
https://quadrajetparts.com/advanced_...sort=4a&page=3
