Rear armrest ashtray
I need to modify my rear armrests in my 72 to fit the rear ashtrays. Can anyone with the rear ashtrays measure the distance from the front of the armrest to the edge of the chrome bezel, and also from the side to the edge of the bezel. If you have an armrest without the tray in it, the dimensions to the edge of the hole would also work.
The ashtrays I have are original to the car, but the original armrests were rotted and tossed out years ago, now I want to modify my replacements. Thanks guys!
I built it one piece at a time and it cost me more than a dime. |
Maybe someone could explain how best to cut the opening for the ash tray when using a standard interior panel.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1993 Trans Am 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 2006 GTO |
Yeah, any advice on that would be helpful, I was going to go at it with a Dremel and small cutting disc.
I cut them with a small "air saw" . If nobody finds the dims, I will dig one out and measure
I am finally getting to the bottom of my extra parts, and yesterday I found a shoe box that contained a pair of these.
I had to take some steel wool to mine to clean them up, I could not find any part numbers though other than the letter K stamped on the out of site edge of the bezel part.
hmm, interesting thought.
If no one posts dimensions, i will go the the garage (where i moved said shoe box last night) after work, and measure them.
Just a stamped "K" as mentioned;
these are tight measurements to the tray under the lip; 2-5/8" x 1-3/4+ (maybe 1-25/64") The top/outer lips measures: 2-7/8" x 2"
Thanks unruhjonny, but what I am still looking for are the measurements to help locate the hole I have to cut into the armrests. Since we both have K stamped ashtrays I will measure mine to see if they are the same. I have some pictures from the internet that I can approximate but there is that old saying "measure twice, cut once".
Thanks again,
oh - sorry for my misinterpretation!
Maybe find someone who has a car with them, and PM them for measurements? Do the undersides show any rough template of where they should be? I have often found in situations like this, the underside of the panel should have markings.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
That's great! Any chance you can throw a ruler on it and take a photo?
Did factory cars come with ash trays or were they always added later??
I've got two rear arm rests with ashtrays and I figured they were junk.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
I don't recall seeing them in untouched standard interior cars. I know for a fact the '73 Formula I had (deluxe interior) had them.
Thread Tools | |
Display Modes | |
