Where Do These Two Plastic Trim Pieces Go?
I cannot remember where these two pieces go.
Near the windshield/headliner? Ames Catalog calls them “Front Windshield Upper Inner Lace” Could someone post some pics please? Thanks, Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
Appear to be the bottom finish trim for the rear shelf Sail Panel "Ear Muffs"
used on the first design (Small Panel)
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:18 AM. |
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
I agree with Jeff's assessment. First design smaller headliner "ear muff" bottom trim. Still not sure when the switch to the larger one occurred, which I think also eliminated one of the headliner bows?
The Following User Says Thank You to Andre For This Useful Post: | ||
That solves my issue! Don
Good to see that you're working on the little fiddly bits to get the car 100% back together, Don. Every little bit helps.
Jeff |
Thanks Jeff. I’m currently having the headliner and seats redone .
