Old 01-24-2021, 04:22 AM
66 tempest's Avatar
66 tempest 66 tempest is offline
Default Backup light switch.
I have a 72 manual trans with 64 tail housing, can I use a 65-67 backup switch? Also the trans has a 72 bellhousing can I use an oem flywheel on my 67 engine.. Not sure if you can mix and match parts. I know this is probably an easy questions for you all, but I need to be certain before I order parts.
Old 01-24-2021, 08:23 AM
Jeff Hamlin's Avatar
IMHO it would be easier with the aftermarket BU LT SW.
It utilizes a plunger rather than the small linkage rod, found on OE SW.
If you already have all the OE parts then it's just a matter of setting it up so the function matches the travel of your lever.
You might even need to drill the hole for the small link/rod,
if your linkage mounting lever/tab doesn't have it.
JM2C
Cheers
Old 01-24-2021, 12:31 PM
66 tempest's Avatar
JM2C
Cheers
Thank you.
I dont have any of the original linkage, so the aftermarket will be perfect..
Old 01-24-2021, 03:02 PM
Scott Thelander's Avatar
68 parts work great also
heres a couple pics of my 70 m-22 w 68 back up items
https://www.gtoforum.com/threads/196...switch.133947/
Thread Tools
Display Modes
