WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 2004-06 GTO Owners > 04-06 Transmission Tech
04-06 Transmission Tech Automatic or Manual trans issues
Old 07-10-2014, 04:48 PM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
Default GTO Center Support Bearing Replacement
After GM held these un-serviceable for the longest time, they are now available from the OE source!
Now you don't have to spend $500+ to replace your entire driveshaft.
1. Take the u joint part of the drive and clamp it into a vice (and no someone's buddy just can't hang on to it.)
2. After you have it clamped good and tight, take a hammer and hit the end of the driveshaft that goes to the transmission. NOT the end that goes to rear end and be sure not to hit it as hard as you can. That way you don't bend or break the tabs that the bolts slide into.
3. Once split apart tear off the ring with all the rubber that has failed until just the bearing is left then take a hammer and a chisel and hit on the back side of the bearing till it slides off. It’s kind of tricky because the bearing will want to spin.
4. After bearing is removed slide on new bearing but do not hit bearing with hammer to get it to slide on. Instead take the other half of the driveshaft and use a hammer and piece of wood to hit the two pieces together again and that will set the bearing back in place.
5. Make sure that you have marked both pieces of the driveshaft so there are no vibrations.
http://www.youtube.com/watch?v=7lDr0-Jx8Fc
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
Old 04-16-2015, 09:41 AM
eric_cspan's Avatar
Administrator
Now a lower price at $119.
http://gtog8ta.com/04-06-gto/04-06-g...pport-bearing/
Featured Vendors
Advertising Info
