73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-31-2020, 07:38 PM
jerry455 jerry455 is offline
When I had my Can Am, I ran 255 60 r 15 tires all the way around on some 8" snow flakes.
Old 07-31-2020, 08:22 PM
moontower69's Avatar
moontower69 moontower69 is offline
Default 255 60R/15 all around is way to go!
That's the biggest that will work. I have mine on stock Rally 11 7x15.
If you get Wheel Vintigues 15x8 rims you can go bigger but will have to deal with backspacing issues.
I think 255s are perfect.
ID:	546216   Click image for larger version
1974 Lemans Sportecoupe GT (daily driver)
"Well the girls out there knock me out, you know
Cruisin' around in my GTO"
Rock 'n' Roll High School
Ramones
Old 08-10-2020, 12:26 AM
BR57's Avatar
BR57 BR57 is offline
Couldn't leave the car alone, decided to pop on the standard 1973 hub cap for yet another look. You don't see a '73 dressed like this very often.
Ray White
Toronto - Canada
Old 08-10-2020, 02:13 PM
cdrookie cdrookie is offline
^^^ looks killer! leave them on there.
Old 08-20-2020, 12:37 AM
Brian Baker's Avatar
I've got 255/60's mounted on 8" Snowflakes on all 4 corners of my Can Am. Will be replacing the tires before next year and thought about a 275/60 in the rear, but I'm not sure they won't rub with the 8" Snowflakes. I have just enough room to fit my fingers between the sidewall and the wheel opening trim with the 255/60.
Old 09-30-2020, 08:29 PM
stobin's Avatar
stobin stobin is offline
Default Rear Tire Size
I run a 305/35/19 on the rear but the wheels were custom built for the GA. Wheels are 19x11 rears, 19x9.5 front. No rear fender modification required as long as the offset is correct. No rubbing. Tire is 27.5" diameter. Rear differential is stock width.
ID:	550663   Click image for larger version
ID:	550664   Click image for larger version
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme.
Old 10-01-2020, 01:04 AM
That's what I am running on my Can Am now, and there is just enough room to get my fingertips between the sidewall of the tire and the inner lip of the 1/4 wheel opening.
Old 10-01-2020, 02:35 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
This car also looks amazing. Wheels are perfectly sized and fit the look of the car. The black trim is cool and I dig the trans-am style exhaust after the wheel. Excellent job.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 11-23-2020, 09:12 PM
Arocket Arocket is offline
79' TA WS-6 Snowflakes zero offset
295/50/15 on the rear
275/50/15 on the front
No clearance issues and looks really good!
