#41
When I come off the stop around 3.6 seconds it runs hard to the finish line. Anytime you pick up hp the mph goes up. Plus you can look at your Racepak and see where it picks up. I’m crossing the finish line at the same rpm at the same mph
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
#42
Jimmy,
I like to play with simulations. How close is 9.383 @ 1000 foot to what you run. Based on simulated run of 10.901 @ 151.28 MPH. Stan
#43
So what did the heads flow before BES this time?
#44
Curious what rpm you shift at and cam specs. Kind of surprised by the results
#45
Maybe the converter is too loose after the head tune up?
#46
SD |
#47
That’s pretty much the number
#48
414 intake I don’t remember the exhaust right off
#49
what is the first number on the stop ?? is it air or electric and where are you shifting?? 3.6 seems like a lot of timer --
#50
I’m .05 1st timer and shifting at .05. 60’s are 1.91. Rpm is 3950-4000. I had 3.60-3.70 in the second timer last year and the same thing this year. It’s like I never touched the motor. It runs exactly the same. I have the APD Maxspeed carb 1250. It’s air and the shifter is electric.
#51
Brakes dragging?
I didn't see your car there Friday? Did you leave?
#52
Try going back to the 1050 Carb.
#53
1st of all imo this does not suck. You didn’t go backwards and that’s a bonus!
2cnd you had some high quality work performed and now have higher quality parts. 3rd I’ve been in this exact spot before. Long story short. I didn’t start seeing considerable gains until I started playing with torque converters. With the current state of events. It looks like we might have some down time. So maybe some dyno time might be a good place to start. Find a happy place with fuel and timing. And maybe a few carb spacer changes that can answer your questions from another thread. It does’t matter “how much it makes”,however, it does matter that you can take some tangible,visible information to a converter manufacturer and they can get you closer if you decide to make a change with converters. I’m guessing a lot of good dyno operators could agree that it doesn’t matter if it’s a “happy dyno” or a “conservative dyno” your peak horsepower and torque will Occur at nearly the same rpm. And your curves will look very similar. I’ve come to realize that dyno info is just as valuable as our racepak data. The dyno time is fairly cheap and a lot quicker to get data considering It averages out for us to pay roughly $50-$75 per pass to go down the track at division races.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23 Last edited by S/st 54; 03-14-2020 at 01:29 PM. |
#54
Soooooo do you have a racepak on the car ?? if so what is the converter slip at the top end -- Logic would tell me you have some other issue going on - restricted air scoop -- rev limiter doing funny stuff -- something that when you find it will be an AHH HAAA moment.
#55
Sounds like the motor liked the velocity over the increased airflow if rpm points and finish line rpm is the same. Time for more rpm?
If no dyno time after head work, pretty much a guess as to what the motor likes.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Last edited by J.C.you; 03-14-2020 at 08:20 PM. |
#56
#57
JC you may be right and I hate it got finished so late I didn’t get it on a dyno. That always means a time consuming guessing game..,
#58
maybe I missed it but I never saw the trap rpm listed ??? I also have some concerns about the runner divider length in the plenum.
#59
I’m 7500-7550 at the trap. Are you thinking the dividers should be cut back shorter?
#60
I know those in my intake were cut back -- its important to know the distance from the back of the intake valve to the opening in the intake at the plenum -- just a thought 7500 seems high for 150 mph what tire and what gear ???
just for compare my s/g car is 7900 at 174 --- 4.30 gear and 33in tire |
