Industry Stuff new repro's, updates, other info.
Old 10-06-2017, 02:36 PM
Ken'sGTO's Avatar
Ken'sGTO Ken'sGTO is offline
Default 67 GTO Dashboard
Who sells complete dashboards for GTO? Need one for my 67. Thanks
"Experience is what you get when you don't get what you want!"
Old 02-10-2018, 03:03 PM
ERIC AULL ERIC AULL is offline
Ames sells the dash housing...Pete Serio at Precision pontiac can furnish you a set of gauges etc.....
Old 09-04-2018, 05:46 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
I bought a complete dash from Ames, pretty good piece, stamping on the back of the housing "Parts Place Inc". It is missing on hole in lower panel, beside the steering column tho
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
Old 09-06-2018, 01:20 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Those are good pieces. Considering your only other option, nowadays would be to strip and re-chrome your old bezel. That can take 6 months up to a year to get back. Then it needs painted. The outside color; to match the interior color of your car plus the tunnels on a 67 are a flat dark jade green. You will have to make cardboard templates to cover the chrome. Never ever use use masking tape on a freshly re-chromed bezel!!!
On the new reproduction bezels the chrome is nice and shiny the plastic is brand new. There is one tiny issue with the new bezel for 1967 Lemans or GTO which is not a big problem to cure.
One of the mounting posts on the back is molded in error 1/8" too short.
It is the top row post, one of the ones that hold the main housing. Reading from left to right it's the one right in-between the 1st and 2nd circle openings. I shim it up using a couple of small washers. On that one post you then need a slightly longer screw, but make sure it's the same diameter and thread pitch as all the rest of the screws on the back. Those gauge mounting screws are a certain size and they are very thin.
I would NOT use an oversize or a regular machine screw in there or you run the risk of cracking or splitting the post.
Name:	~0000_1967 New Dash Bezel and Gauges~tpp.jpg
Peter Serio
Owner, Precision Pontiac
