Autolite ASP AP85 any good?
My local NAPA does not carry AC Delco plugs for my 1970 T/A RA3. They show Autolites as a substitute. Any one here have experience or opinion on these Platinum plugs? Thx.
1970 T/A |
I use Autolite in everything here, but not the platinums. I prefer the standard copper core,... Autolite is an excellent plug.
I dumped AC a long time ago when they started deleting various heat ranges and monkeying around with their number system. |
Ditto what Formulajones said. We use the standard Autolite copper plug in both my 403 olds and in Curtis's 400 poncho. Heat range 85; they have given excellent service.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
Add me to the list of those who use Autolite’s copper plugs... 💪🏾
Same, here.
No need to spend the $$$ on platinum...ever...
I have never had a Autolite plug let me down.
Do not use platinum plugs in a carbureted engine. They are intended for FI engines with constant precise metering. I had many customers cars here with platinum plugs and engine not running right because of it. Stick to copper core
Carburetor building & modification services Servicing the Pontiac community over 20 years |
I use autolites in everything except my 69 which I use NGK's. I've hear about the platinum plugs in carbureted cars but never quite understood. Can you tell me more about it?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Thanks for all of the great input! Autolite copper it is then!!
1970 T/A |
Yep. Changed over to Autolite after Champion went down hill followed by Delco a few years later.
What # Autolite plug replaces the AC Delco R44S plug. (copper). Also the NGK equal.
Thanks |
That would either be an XR4 in NGK or an Autolite 85
NGK is a great plug too. Just have to remember the heat ranges on those work backwards from our traditional way of thinking.
For a colder plug the number goes up, not down. |
This is probably a discussion for another time, but with my engine set up with lower compression than stock (9.3:1) and spending more time leisurely cruising than hauling the mail, I usually run Autolite 86 plugs which is equal to the AC R45S plug. The overdrive trans also keeps the freeway trips down to a rather mundane range in the low 2,000's.
