No...heres a thread when I was thinking about trying a rob mcc pump. Never did use it and am still running the carter. The 11 sec runs I mentioned was with a auto tran and 3.70 rear gear,sticky tires but same car.
https://forums.maxperformanceinc.com...=860736&page=2
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
The Following User Says Thank You to scott70 For This Useful Post: | ||
Where is the M6907 flow rating of 120 GPH shown? All I can find is 40 GPH minimum flow at 6.5psi directly from Carter.
Not saying that the 40 GPH is right or wrong but I'll post the link again. https://carterengineered.com/mechanical-fuel-pump-m6907 |
