Old 02-08-2018, 10:06 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Great shot of the engine, especially with that coil bracket in the right place ;-)
  #142
Old 12-05-2018, 01:57 PM
SD455DJ SD455DJ is offline
Finally some progress on the body! Just needed a little patch work at the base of the windshield and lower rear window channel. Front fenders have small holes that will be easy to patch. Floor and trunk were great.
Dennis
ID:	499446   Click image for larger version
ID:	499447   Click image for larger version
  #143
Old 12-05-2018, 06:46 PM
gtospieg gtospieg is online now
glad to see some progress...looking forward to seeing more updates...
  #144
Old 12-05-2018, 08:53 PM
Pontiac_Defender's Avatar
Pontiac_Defender Pontiac_Defender is offline
Thanks for the update! I love following builds like this!
1967 2+2 hardtop 428 w/auto
1967 2+2 convertible 428 w/4 speed
1967 2+2 convertible 428 w/auto
1967 Bonneville Brougham Coupe 428 w/auto
1967 Grand Prix convertible 428 w/auto
https://www.plainfieldpontiac.com/
*BE SURE TO LIKE MY FACEBOOK PAGE* https://www.facebook.com/PlainfieldPontiacRescue/
  #145
Old 12-06-2018, 03:37 AM
mnfatcat's Avatar
mnfatcat mnfatcat is offline
A friend with the same rear window issue told me had it down to bare metal, took a small piece of fiberglass mat saturated with Por 15 and layed it in the recess . I'm thinking of doing the same, but just Scotch Briting the trough fixing the rust hole area and painting the whole trough with Por 15 side to side.
68 Cat 2 dr sedan 461ci 670 heads XE284H 850 Holley
493/525 wide ratio 4sp 3:42 posi 13.07@105 full exhaust
  #146
Old 12-11-2018, 08:00 AM
More of the under body work...the heavy trans and oil pan leaks undercoated the floor and did a great job of rustproofing. Had a small patch panel in the trunk where the grease didn't reach.
Dan's assembling the front and rear suspensions (assembling the 4.11 rear end) and steering assembly to be ready to drop the body on soon. Painting Verdero Green this week!
Dennis
ID:	499906   Click image for larger version
ID:	499907   Click image for larger version
  #147
Old 12-11-2018, 03:46 PM
Stuart's Avatar
Stuart Stuart is offline
Nice and clean under there.
Looking forward to pictures of the painted body!
  #148
Old 12-13-2018, 01:43 PM
These pictures are from the work completed yesterday...getting closer to paint, but probably next week. Dan said that there was a little more sheet metal work than I originally thought. He said there was a small driver floor section, the pass side small section of trunk floor, both lower sections of the front fenders, small sections of the lower windshield and rear window channels, both lower rear quarter panels behind the axle and drop panels, both doors, and the hood (holes drilled in the original for the homemade mailbox hood scoop)...OK, so a lot more than a knew off...I'm not there everyday, so I miss things...
ID:	500064   Click image for larger version
ID:	500065   Click image for larger version
ID:	500066   Click image for larger version
ID:	500067   Click image for larger version
  #149
Old 12-13-2018, 09:01 PM
Stuart's Avatar
That's still a relatively short list for a 50 year old car.
  #150
Old 12-14-2018, 08:15 AM
More chassis assembly pics and the VooDoo paint arrived!
Dennis
ID:	500135   Click image for larger version
ID:	500136   Click image for larger version
ID:	500137   Click image for larger version
  #151
Old 12-23-2018, 08:00 PM
Frame is almost a roller now...just waiting for the front wheel cylinders. Dan most likely has the rear brakes installed today though not shown in these pics from Friday.
Dennis
ID:	500801   Click image for larger version
ID:	500802   Click image for larger version
ID:	500803   Click image for larger version
ID:	500804   Click image for larger version
  #152
Old 12-23-2018, 09:16 PM
Stuart's Avatar
It's going to be like a brand new car.
  #153
Old 01-13-2019, 04:49 PM
The brakes are finished now and a true rolling chassis and going over to Scotts (Scott Tiemann's Supercar Specialties). Motor...done. M-21...done. Paint next week!
Dennis
ID:	502791   Click image for larger version
ID:	502792   Click image for larger version
ID:	502793   Click image for larger version
  #154
Old 01-14-2019, 10:21 AM
63 Pontiac's Avatar
63 Pontiac 63 Pontiac is offline
What are you using for rear lower control arms?
1963 Catalina 2 door hardtop
1968 Catalina 2 door sedan
  #155
Old 01-14-2019, 10:28 AM
63 Pontiac - Dan just restored the original suspension pieces and installed new rubber bushings...nothing special. The frame and suspension components were all powdercoated semi gloss.
Dennis
  #156
Old 01-14-2019, 03:54 PM
63 Pontiac's Avatar
Ahh, they looked like they might be a tubular aftermarket piece. RARE was making a rear suspension kit for the b-body cars but it's not on their website anymore.
Thanks!
Phil
  #157
Old 02-22-2019, 03:45 PM
chicagoland chicagoland is offline
Posted before how much I like this big Poncho, glad it's getting nearly finished, can't wait to see final pix!
  #158
Old 05-21-2019, 07:15 AM
The big 'B' body getting it's finish body work prior to the paint going on...finally! The chassis is ready...the 428 HO and M-21 are ready...the interior is ready...now it reassembly begins after the paint work is done.
Dennis
ID:	512664   Click image for larger version
ID:	512665   Click image for larger version
ID:	512666   Click image for larger version
  #159
Old 05-23-2019, 10:06 PM
Stuart's Avatar
Looking forward to paint and final assembly.
  #160
Old 05-24-2019, 07:15 AM
coonhunter70 coonhunter70 is offline
