Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-03-2018, 02:53 PM
mysticmissle's Avatar
Default parts to norwalk
1. Moroso vac pump catch can #12 fitting and breather small dent underneath mounting bracket. $40
3/8 thick round port header flanges 2 sets $40 each
Used Pete Jackson gear drive $100
NX fuel nitrous and purge solenoids carbon fiber. $150 for set with NX gemini 6 dominator plate and jets $350$
HAL front shocks adjustable with extensions for any abody. One needs rebuild $25
Harold Brookshire speced big UltraDyne dyno solid roller less than 50 passes. .456 Int .454 Ex. 280 288. 110 lsa. 800hp cam in right motor. $300 shipped
http://i437.photobucket.com/albums/q...psqovs3sm8.jpg
Nos set of Crane solid flat tappets. Oil band in correct spot for pontiac. Early 80s or older vintage. $100 shipped
Pi
http://i437.photobucket.com/albums/q...psrffhn3yt.jpg
1964-72 A body, x body and f body discs Will fit f body if you swap steering arms from spindle to spindle --------------------------------------------------------------------------------
I have complete set up will fit all A bodies and Early f bodies. came off my GTO a few years ago, origially off 1971 Buick. low usage, some surface rust on rotors. complete also have long wheel studs. $300 delivered to Norwalk with a deposit . PM i will take pics
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-18-2019, 09:16 AM
NX fuel nitrous and purge solenoids carbon fiber. $150 for set with NX gemini 6 dominator plate and jets $350$ now $300
FREE DELIVERED TO NORWALK IF YOU CAN REBUILD ONE OF THEM> HAL front shocks adjustable with extensions for any abody. One needs rebuild 68-72 a body
SOLD Harold Brookshire speced big UltraDyne dyno solid roller less than 50 passes. .456 Int .454 Ex. 280 288. 110 lsa. 800hp cam in right motor. $300 shipped
Pi
NO LONGER FOR SALE 1964-72 A body, x body and f body discs Will fit f body if you swap steering arms from spindle to spindle --------------------------------------------------------------------------------
1964 540 gto
