Old 11-06-2018, 02:41 PM
wmr5163 wmr5163 is offline
Default rear shocks
Hey guys,
Its been a while since I posted here but I have a quick question. I have a 1971 GP ans was wondering if someone can recommend a some good rear shocks to bring the ass end of the car up a little. The car came with factory air shocks and I'm tired of dealing with them. I'm trying to improve the cars stance a little. Any advice would be appreciated.
Warren
Old 11-06-2018, 03:00 PM
Shocks absorb shock that is why they are called "shock absorbers". They do not "hold up" a car. If your rear is dragging it is because your springs are shot. Air shocks, or worse, those springs they sell that go over your shock are a barn job bandaid and actually cause damage to the shock's upper frame mount which is not designed to take a load. Yes your car may have "factory" air shocks but back then they would sell a customer any thing they wanted. If you noticed, they stopped doing that.
Old 11-06-2018, 06:38 PM
OG68 OG68 is offline
After you replace the springs put some Bilstein shocks under it.
2007 Cadillac SRX
Old 11-06-2018, 07:02 PM
I was going to suggest that but did not know if they are available.
Old 11-06-2018, 07:10 PM
Summit has them listed for GTO. I'm assuming they're the same as GP.
https://www.summitracing.com/search/...tiac/model/gto
2007 Cadillac SRX
Old 11-06-2018, 09:43 PM
Sprocket's Avatar
Sprocket Sprocket is offline
Yes GP and GTO shocks are interchangeable.
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
Old 11-07-2018, 02:32 PM
Thanks for the replies...would you recommend going with the heavy duty coil springs or stay with stock ones? The car is a '71 G/P 455 with 88000 original miles on it....
Old 11-07-2018, 02:44 PM
I would go with stock if you do not tow.
Old 11-12-2018, 02:37 PM
thanks for the advice...I installed coil springs over the weekend and they turned out awesome..really improved the stance of the car. BTW, does any one know where I can get rear bumper pocket that goes behind license plate?
Old 11-13-2018, 12:26 PM
ssj71's Avatar
ssj71 ssj71 is offline
Default Rear Pocket
An NOS license plate pocket is one of the holy grails in 69-72 GP world, and honestly, even if you found an NOS unit, it would be brittle, extremely fragile, and not worth putting on the car, especially after what you're likely to pay for one.
This is one option (but I can't speak about fit or finish on these):
https://www.ebay.com/itm/1971-1972-P...frcectupt=true
1970 SSJ: 272
1971 SSJ: 157
1972 SSJ: somewhere between 60 and 350...
