Old 11-15-2018, 05:38 AM
fbd73's Avatar
fbd73 fbd73 is offline
Default Aftermarket dash gauges
Hi All,
I am thinking about changing out all my dash gauges with aftermarket ones. Has anyone done this and if so, what brand did you use? Pics and measurements would be great.
Old 11-15-2018, 10:36 AM
HWYSTR455's Avatar
Basically, if you have an A/C car, you lose the 2 center vents if you install a full set of individual gauges.
But you can look at the Thunder Road inserts, they allow you to look at diff gauges installed.
http://classicdash.com/product/1970-...-meter-gauges/
You have to wire them, either tap into the OE harness, or run separate wires. Either is not a bad job.
If you wanted, believe several companies offer larger gauges that will fit better in the existing holes of the OE insert, and they make them with up to 4 gauges in one housing (quad gauges).
Old 11-15-2018, 10:45 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
I used speed hut. Lots of features, custom designs easy installation. No pictures currently que’d up but a quick search will show a few guys have used them.
Good stuff!
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 11-15-2018, 10:46 AM
455TA's Avatar
455TA 455TA is offline
Speedhut Gauges. Easiest install for 2nd gens. They're 1 inch thick and light enough to mount directly to the bezel with a large Nut on the back, as the gauges are threaded.
They come with their own harness built in, and they can be daisy chained together with pin connectors that are already installed. You can plug them up directly to the fuse block with an add a fuse.
They make them with multiple gauges built into one gauge, or just individual gauges, so you could retain your center AC vents if you want.
Oh and they're 100% customizable.
www.speedhut.com
1980 Trans Am - Street/Strip 462
Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas.
Admin of Pure Pontiac Powered Outlaws on Facebook.
Old 11-15-2018, 10:49 AM
455TA's Avatar
Here are two pics of the Speedhut Gauges I put in my TA.
They are LED. You could even make them look factory style if you wanted.
ID:	497891   Click image for larger version
Old 11-15-2018, 11:20 AM
lfdsteve's Avatar
Sorry about bad pictures.
Speedhut brand.
ID:	497895   Click image for larger version
Old 11-15-2018, 08:40 PM
JUDGE3 JUDGE3 is offline
Speedhut. build em how you want em. I paid extra to remove the speedhut logo as well for a factory look but far better love the quarter mile et mode and built in shift light in the tach.
Old 11-16-2018, 12:25 AM
Formulabruce's Avatar
No speed hut analog looking clock?
Old 11-16-2018, 08:19 AM
ahhh the clock. I had a new 1980 trans am with the infamous clock. always hated it. thought it dumb and still do lol. who gives a care what time it is when driving one of these awesome cars? the shift light takes it place ha.
but, for clock lovers you can get one in there. analog clock in a performance car? what?
Old 11-16-2018, 11:18 AM
HWYSTR455's Avatar
I did The Judge logo on my SpeedHut gauges....
Old 11-16-2018, 11:25 AM
HWYSTR455's Avatar
Classic Instruments makes 4 5/8" gauges:
https://shop.classicinstruments.com/ax56gblf
https://shop.classicinstruments.com/hr56slf-2
https://shop.classicinstruments.com/vs56bblf
Old 11-16-2018, 03:17 PM
My interests are in a Touring type build, so was just curious. Probably an aftermarket radio would do this job though.
Old 11-17-2018, 07:19 AM
fbd73's Avatar
Hi All,
This is great info. I've checked out Speedhut and really like their range. I live in Australia so am wanting the speedo to be in kilometres per hour not miles per hour and they do a gauge set to suit.
Now, my question.
Can you please tell me the measurements of the gauges that will fit into my standard dash?
I think the speedo and tacho are 3 3/8 " and the other gauges are 2 1/16". Am I correct?
Old 11-17-2018, 03:21 PM
Lee's Avatar
Lee Lee is offline
I've worked with New Vintage Gauges for my Cutlass project. Their customer service is EXCELLENT. They recently corrected some issues on gauges that were well out of warranty - they did not charge me anything, not even shipping.
I've thought about contacting them about some direct-fit T/A gauges.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 11-17-2018, 08:05 PM
Originally Posted by fbd73 View Post
Hi All,
Now, my question.
No, mine are 4" for the big holes, yes, 2 1/16 " small holes.
Old 11-19-2018, 08:11 AM
fbd73's Avatar
Has anyone fitted the Speedhut gauges with the GPS speedo? I am interested to learn how the antenna is mounted and if it is easy to fit and connect and if it works well.
Old 12-11-2018, 10:08 PM
70UglyBird 70UglyBird is offline
I have it. I have it right up on the dash. Dont really notice it. Works well unless your in a tunnel
1973 Firebird, Formula hood, 466 roller cam, ported heads, T56, Hotchkis springs, Koni shocks, DSE Subframe connecters, PTFB upper a arms, re-enforced lowers with global west delrim bushings, C5 brakes front and rear, 18 inch Boss 338 wheels, 4th gen TA power seats seats, Morris seatbelts, hydrotech hydroboost, speed hut gauges
1973 Formula 4spd long term project
Old 12-21-2018, 10:13 AM
Zyman's Avatar
Zyman Zyman is offline
Default Dakota Digital
The best on the market IMO. http://www.dakotadigital.com/index.c...rod/prd930.htm
"Pride Precedes The Fall"
1968 Firebird Undergoing Transformation
1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered
2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track.
Old 04-06-2019, 07:26 AM
schultcd schultcd is offline
I just received my Speedhut gauges. I got the 4 1/2” speedo and tach because the bezels are the same size as the originals. The holes will need to be trimmed slightly for them to fit, however. I hate to trim my original bezel so I might use a later “RTS” bezel instead. Might try filling the holes before sending it to Randy for restoration. Has anyone ever done that? The 2 1/16” gauges fit directly in the existing holes with no modifications.
Speedhut was very good to work with on the design process. If anyone is interested in doing this, they use Adobe Illustrator in their graphics department and the have some blank templates on their website. Just send them your file and they’ll make the gauges with your graphics. I’m no graphic designer, I don’t know how many hours I spent trying to get mine to look the way I wanted. They’re still not perfect but I’m happy with them.
Old 04-06-2019, 07:54 PM
very nice design. i'm sure that took some doing to get that right. the factory guys will have to look twice to figure that dash out. good job, post when its all in and lit up!
