1974 GTO VIN number decoding
When evaluating a possible 1974 GTO for purchase, the prospective buyer can do some quick due diligence to see if it is a factory produced '74 GTO or a "tribute" or "clone". The first seven digits of the VIN # can give you a pretty good indication before you ever get to ordering PHS documentation on the vehicle.
1st digit should be 2 for Pontiac 2nd character should be Y or Z for base or custom Ventura 3rd & 4th digits should be 17 or 27 for hatchback or coupe 5th character will likely* be B for 350 ci 200 HP engine 6th digit should be 4 for 1974 model year 7th character is the assembly plant (W= Willow Run, MI, L=Van Nuys, CA) 8th - 13th digits are the sequential build # for a specific car Ex. 2Z17B4W??????. I have had a 1974 GTO in my possession since it was born in 1973 and my VIN is 2Z17B4....... I know a K for the 5th position is listed in some literature as the 350ci 4bbl, dual exhaust for 1974 Pontiacs, but I haven't seen a 1974 GTO VIN that doesn't have the B engine code in the 5th position, but perhaps there were some produced with a K in the 5th position of the VIN. Hope this helps anyone to be able to do a quick VIN decoding to see if the car they are looking at is a factory '74 GTO. |
I almost passed on a real 74 GTO many years ago because the 5th digit was a B, and the literature I had said it should be a K. Fortunately, a little further research convinced me the B was correct....
Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
That said, I'm looking at this as a positive thing: no need to preserve the column shift automatic as a quirky option. Time to find a complete floor shift manual transmission setup. That American Powertrain TKO600 is looking mighty attractive, if I can find the funds. Its' also no longer necessary to save the 350, since it's not the VIN number original engine. It is a real 200HP, screw-in stud 350 though. I assume it has little more than scrap value. Any advice on locating a stick shift setup? Do I need a blowshield if I only run the car on the street and NEVER powershift? Stuart |
Thread Tools | |
Display Modes | |
