Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 12-01-2018, 05:56 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Default 71 -72 GTO rear brake line flex hose
I ordered P/N R187LF and received P/N R187LD instead. I called as soon as I saw the part was wrong and the guy on the phone said that the part I was sent is what you sell when P/N R187LF is ordered and that it will work. I asked why list the LF part in the catalog if that’s not what you send? Got the it will work response. Figured this would be better than nothing. I was wrong. Went to put it on and it will not work. The bolt used to hold it to the bracket won’t fit through the block end.
Smilies are Off
