Old 03-05-2019, 07:28 AM
Jeff Hamlin's Avatar
Exclamation 4BC HEAT VALVE/GATE CONTROL PIECES
Anyone out there with factory heat gate still in operation.
Im trying to match/replace a few missing bits.
The parts in red are what Im looking to find better details on.
If you can provide better images and/or specs to these and/or suitable replacements I would love to hear from you.
Thx
Old 03-06-2019, 07:36 AM
I'm looking for details on the Retaining/anti rattle clip #60 and the Spacer #46.
The Shield/Cover is unique and first I've come across in years.
What I'm not 100% sure is if this was across the board on ALL 4BC manifold or certain years.
I purchased a thermal spring that was listed as all Pontiac but it was/is way to large so even the spring is different.
Looking on a Willys 6cyl parts site and going to try one of their offerings on springs.
Old 03-08-2019, 02:06 PM
Hokie1984 Hokie1984 is offline
Jeff search the Cammer website. I bought the anti rattle spring and coil from a 1950’s Chevy website, worked well. The cover is a different story.
Old 03-09-2019, 10:29 AM
This is the one I think I used.
https://www.chevsofthe40s.com/detail...hermostat.html
Old 03-10-2019, 08:38 AM
Thumbs up
Thanks,
I've seen the Chebby 6 as well as the Willys 6 I mentioned, just need to figure out it they will fit under/into the cover/shield.
Guess I'll buy a few and see how it works out.
Re-Creating the Spacer shouldn't be that hard the Anti-Rattle Spring offerings are close enough to get this back in order.
I lucked out on the '66 with an NOS spring years ago but that will likely not happen again.
Old 03-15-2019, 06:25 AM
Default WILLYS L HEAD COIL
Picked up the Willys spring and though it fits within the shield/cover it has more coil so I'll mock it up and test to see how it reacts.
Old 05-14-2019, 06:57 AM
Thumbs up Update;
Well still tinkering and found the Willy's spring just wouldn't fit/function so I moved over to the suggested Chevy 6 spring.
It fits within the cover/shield nicely but had to roll the end over the pin/shaft to prevent it from walking.
Overall tested and works well.
Might try one more style/model spring just for giggles.
Disregard the zip tie it's just so I don't loose any thing while I search for a retaining/anti rattle spring clip.
Thread Tools
Display Modes
