Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 03-05-2019, 06:54 PM
allenga allenga is offline
Default 77 Trans AM Grill Overspray
Hi. For this part, is there a recommended way to remove the overspray, from the chrome. Thank you.
FB285R 1977 Grille, Trans Am and Formula, RH (RE)....... 139.00/ea.
FB285L & FB285R exhibit minor flaws from the chroming process and
slight overspray may be evident. Quality is still considered very good.
Old 03-06-2019, 11:06 AM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
The key is to be careful. We have tried a few methods in the past. Mask off any painted areas around the chrome in order to prevent damage, and use a mild reducer on a cue tip to lightly brush over any over spray. Then clean the chrome with a light cleaning solution. Like I said, it is key to be careful not to damage the chrome, as it will scratch and distort easily.
[/SIGPIC]
Old 03-06-2019, 11:49 AM
Thank you. What is a mild reducer. :-)
Old 03-06-2019, 12:04 PM
AMES-TECH's Avatar
A medium reducer designed for paint will do.
[/SIGPIC]
Old 03-06-2019, 05:35 PM
TAKerry TAKerry is offline
Just a hypothetical, but these are not cheap items. Can you not inform your supplier to do a better job in the manufacturing process or you will not accept them, thus not having to explain to the end user how to fix a known problem ?
Old 03-07-2019, 10:24 AM
AMES-TECH's Avatar
We always notify the manufacturers when there is a problem. The factories build thousands of one specific item at a time. Hence the reason we have to wait until the next run for a problem to be fixed. We are on top of every defect that comes across our desks, sometimes it just takes a little more time to fix.
[/SIGPIC]
Smilies are Off
