#41
NEVER said you were!
You would know your header size. GTO George |
#42
These are my turbo headers. They’re 1.875 pipes. I only have one side but the other side is identical. It has a 2.5” crossover.
#43
Nice.....What kind of HP are you making?
GTO George |
#44
Most people assume that they do but that assumption would be wrong. Pipe Diameter is based on the OUTSIDE diameter of the steel pipe (in a exhaust application). Then you subtract the wall thickness of the pipe you are using times 2. So, 2.0" pipe: if you have a .060" wall thickness your actual flow diameter is 1.875" and if you have a .047" wall diameter you would have a 1.906" flow area. So your Turbo Headers are 1.875" pipes so can I assume that you have roughly a 1.775" flow air for your tubes (assuming a .047" wall thickness)? Or did you use .060" wall thickness tubing. Then it would be even less flow area. Tom V.
#45
GTO George |
#46
Typically in the metal business round tube goes by OD and pipe is by ID.
Pipes are normally used to transport gases or fluids so it is important to know the capacity of the pipe, so ID is the pertinent measurement (e.g. schedule 40). Tube is structural so it is sold by OD. This is often confused. Don't get me started on gauge. That one is fun... Lot's of different gauge metrics, and it changes based on material. Terrible system.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
#47
he made just under on low boost.1400hp
Turn it up Edwin!!
My Half AN Injun..... |
#48
The Turbo Headers made by 455 Turbo (see Post #2 in this thread) were actually made using pipe with a lot of fitting required but they were "works of art" and well designed. Tom V.
#49
The primary tubes are 1 7/8" OD. It was a tubing and not piping, my bad. It should be 1 3/4" ID. to a 2.5" collector.
#50
No Worries. Tom V.
#51
Wouldnt matter any way for what you're doing.
#52
Too many technicalities going on around here! lol
#53
WOW should be a 7 second car......how quick does it run?
GTO George |
#54
His motor made 1160 torque at 3800 rpm lol
#55
GTO George |
#56
ill loc it in for ya George! haha
#57
It is not a 7 second car, that's for sure. It is a street car with a turbo on it. But with a built engine to properly support the power. I'm still not done with the car as I have to fabricate everything in this car. It made good power on the dyno but never ben in this car in 20 yrs. So if I can get it out this year, I will be happy! So no locking in with u George.
#58
I would love to put my car on a Dyno and see what the numbers are, this engine has never seen a Dyno. Even when my first engine was on the Dyno it had smallish headers with only 2 1/8” tubes! I have 2 1/4” now......maybe need to go one size larger pipes.
GTO George Last edited by GTOGEORGE; 05-16-2019 at 10:41 AM. |
#59
It was easy to see the power on the Dyno but I’m not sure how my car would like this much power on it. I’d like to actually drive the car as I Ibuilt it to be a street car. Also this is not on a Happy Dyno either! This Dyno break people’s heart as it’s always making lower than what they have expected.😁
#60
Also, the turbo setup doesn’t like the big primary tubes not like a NA or Nitrous motor. 1 7/8” will support a lot of power. Big tubes will just makes it laggier!
