Old 06-06-2019, 07:35 PM
grd777 grd777 is offline
Default did 1972 formulas or t/a come with a/c dryers
my a/c is apart and i am trying to put it back together , looks like i have a dryer but not sure if it belongs to my car
Old 06-06-2019, 08:19 PM
77 Canamman's Avatar
POA (Pilot Operated Absolute) , not the VIR (Valve In Receiver) system used in later years.
There was a muffler on the passengers side front inner fender.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 06-06-2019, 08:31 PM
SORRY TO MAKE IT MORE CLEAR I ALSO HAVE THE REMOTE MUFFLER
Old 06-09-2019, 08:40 PM
Formulabruce's Avatar
Will have a drier and a muffler. The whole AC system is like a '71, and very similar to a 1970. The ;73 to say 76 are very similar as well. The '72 has a POA valve on the suitcase facing front. The '73 and up use a VIR system, which eliminates parts . These valves separate the high pressure side from the low pressure side, to put in basic terms.
Old 06-09-2019, 08:42 PM
were does the dryer mount on the car
Old 06-09-2019, 09:32 PM
Should be on a bracket near the end of the radiator on the pass side, by the evap tank and the hole for the Condenser. Ill try to get a pic when I can. Mounted vertical. Glass on top.
Old 06-09-2019, 09:49 PM
if you can send a photo that will be great thanks for all your replys to me
Old 06-23-2019, 11:02 PM
schultcd schultcd is offline
Actually ‘73 still had the POA valve. Late ‘72 and ‘73 were basically the same as ‘71 except they had crimped hose assemblies instead of the barbed fittings with clamps.
Thread Tools
Display Modes
