Old 06-17-2019, 11:16 PM
lucky1 lucky1 is offline
Default Dome light stays on.
Sorting out my 65 GTO. The dome light has never worked. Checked the bulb and it was missing.
Installed new bulb and its on all the time with doors closed.
Unscrewed from roof, wires look fine
When hanging by wires alone it works as it should.
As soon as the screws go back in it comes on and stays on.
Thanks for your help in advance.
Old 06-17-2019, 11:30 PM
Make sure wire is not hitting roof or that the screw is not in the wire. The wire from the bulb is grounded by the door switches and the headlight switch. Something else is doing it. If the light works correctly when unscrewed from the roof some part of it must be hitting the metal roof.
Old 06-17-2019, 11:35 PM
I can push the fixture hard against the roof and move it around, works as it should.
Only stays on when screws are in it.
Old 06-18-2019, 05:50 AM
Geoff Geoff is offline
Chasing two problems here.
Light stays on only with screws installed. That is because the screws are earthing the light frame, reqd to complete the electrical cct.
Light on with doors closed. Could be h/light sw knob rotated all the way CW, switching on the lamp.
If not this, likely to be the door switch. This happened on my GTO. I glued a small 1/16" thick piece of alum to the door to push the sw plunger in a little further.
Old 06-18-2019, 11:04 AM
That's what it's doing but it's not suppose to. Dome light wire is hot at all times. The only grounds, to turn it ON, are through headlight switch and door jamb switch.
He's got something touching making ground when he puts the screws in.
Needs to give wires and fixture a good inspect to see what's making contact when it ain't suppose to. Melted/broke insulator, bare wire on top, screw through or pinching wire...Just something making contact when he tightens it up.
Clay
Old 06-28-2019, 03:22 PM
Default Update.
After trying this and that, it seems the fault is in the fixture.
I insulated the shafts and heads of the mounting screws.
Light now works as it should. The fixture is a new one from our host.
Old 06-28-2019, 04:11 PM
FrankieT/A's Avatar
This may sound stupid...but check your fuses...sometimes when your brake light fuse blows your dome light will glow.
Old 06-28-2019, 08:32 PM
Default Thank you!!
I checked my brake lights. They were out!!!!!!
It was a faulty switch though.
It's been months since I checked them.
Thank you for the nudge.
Demonstrates the IMPORTANCE of ROUTINE. Safety checks.
Thanks again!!!!!!!
