Old 06-23-2019, 12:44 PM
grrrrregg!!! grrrrregg!!! is offline
Default 1963 GP 421HO ????'s
I tried searching this out, got conflicting info, even on this site. 1963 GP 421 engine combos. I've seen 2 and/or 3 different horsepower combinations. Which are 421 HO's. What are the engine codes, some sites show 3 engine codes, others show multiple engine codes depending on motor, trans, and rearend gears. Last ?, how to ID a HO vs non HO.
thanks
Gregg
Old 06-23-2019, 02:57 PM
tom s tom s is offline
421 22B 320 HP man trans
421 34j 320 auto
421 43n 320 auto(315)
421 08b 353hp man ho
421 25g 353hp auto ho
421 47q 353hp auto (315) ho
421 11b 370hp man ho
421 28g 370hp auto ho
421 50q 370hp auto(315) ho
did not post SDs,dont no what the (315) is
Old 06-23-2019, 03:16 PM
Believe it's the Super Hydra-Matic transmission.
(375 was the Roto Hydra-Matic)
Old 06-23-2019, 03:46 PM
All 421 HO engines in ‘63 and ‘64 had the 9770716 heads, so that may help you to weed out the non-HO engines.
Old 06-23-2019, 04:23 PM
421 34j 320 auto
I did see these block id's, a few more with 3.90 gears, and 3sp stick. I just read an article I found in a 18 year old PE magazine. No mention of a 320hp 421, just the 353 and 370hp version. Could the 320hp be a big car motor, just not in a GP.
is this on the 2 center exhaust ports
My reason for inquiring is Im looking at a gP 421 4spd, 4 barrel. Manifold and carb is missing but has been replaced with 3x2
Old 06-23-2019, 04:39 PM
Non HO engines with heads that have smaller valves and less cam and CR.HOs got 10.75 CR.Tom
Old 06-23-2019, 04:41 PM
Yes, the entire casting number is located there.
