tri power alternator bracket
Hi guys ,does anyone have the bracket that bolts to the waterneck for the alternator.It has to be for a 1966 tri power,and I also need the bolt that attaches the bracket to the alternator.Thanks for any help.
Tim |
If your speaking of the black painted “strap” which is fastened with a lock nut to bolt from thermostat housing, Ames has it #N142A (65-66 Tri-Power w/PS).
Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
tri-pwr alternator bracket
Thanks Chris , I'm in the process of moving so all my books are still up north.Thanks again.
Tim |
tri-pwr
Chris,do you know if they make a special radiator hose for a 66 tri pwr and a cold case radiator.It seems like the tri pwr hose isn't correct.Does anyone have any ideas on where I might get one.Thanks again so much.
Tim |
Picture?
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Hi Dick,I don't have a pic right now.I thought that someone may have been through this before.I was looking at it before and I think that with some cutting ,nipping and tucking I might be able to make it work.
Thank you ,Tim. |
Sorry, as I don’t know anything about this radiator you speak of. I only deal in OEM cars and parts such as Harrison. Chris.
