Old 06-27-2019, 05:34 PM
Radman's Avatar
Radman Radman is offline
87 degrees with 79% humidity.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 06-27-2019, 05:36 PM
Firedup6975's Avatar
5:30 pm. It can’t go any higher.
~MaryAnn~ AKA "Stickybuns"
1969 Firebird 400 Convertible
1978 Bandit T/A Tribute
1977 RED TA
I'm the FiredUp PY bad girl
Old 06-27-2019, 08:14 PM
GT182's Avatar
GT182 GT182 is offline
That's a good one MaryAnn. Can you imagine the ones working construction and mowing lawns out in the heat.
In a way it's makes up North look a bit better...... not really tho. I still can't stand the cold weather up there. Down here I can always get out of the heat to where it's cooler.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 06-27-2019, 09:26 PM
CraigGT37's Avatar
CraigGT37 CraigGT37 is offline
I work outside around steel pipe. The pipe soaks up the heat and make the temp even worse.
Old 06-27-2019, 10:07 PM
Yes I can imagine it because I live it. Mike does it everyday 10 hours a day. He works in Industrial Construction which is building pads for cell towers, putting laterals in, running pipe, building water treatment and sewer plants, welding, a lot of demolition work. They also do utility finding with special trucks. Anything they tear up to replace broken pipes they must put back exactly the way it was. Sidewalks, yards, streets, man holes, light poles etc. soooooo he is in the heat and cold every day at 62 years old.
1977 RED TA
Old 06-28-2019, 12:42 AM
Chris65LeMans's Avatar
I was in Palm Desert on Monday and it was 109. When I got to my meeting, a crew of gardeners was mowing the lawn/trimming the hedges.
Old 06-28-2019, 09:01 AM
TAKerry TAKerry is offline
Im an outside worker as well. A couple of years we were putting a steel roof, mill finish, on a large industrial building in July. Ground temp was in the 100's, I cant imagine what the temp reflecting off the metal was, but it was HOT Seems about every july or august we get a roof job.
Old 06-28-2019, 09:26 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is online now
Its so hot - I saw some meth addicts putting the copper back into an air conditioner.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 06-28-2019, 11:15 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Damn.
Old 06-28-2019, 05:19 PM
GT182's Avatar
In the thermometer in the shade stayed a 100°s all afternoon. Just now it dropped to 98. But the reason being for the drop in temperature is.... we have a storm brewing.
Gary
Old 06-28-2019, 05:46 PM
But I was in the air conditioned hospital a good portion of the day.
Old 06-28-2019, 05:54 PM
bird72's Avatar
bird72 bird72 is offline
Originally Posted by Chief of the 60's View Post
90
much as I've given you cr@p over thread BS, I hope you are OK.
also.... 72 today
72 Bird
Old 06-28-2019, 06:01 PM
also.... 72 today
Sore.... pain.... Pills are helping. Thanks
Old 06-28-2019, 06:06 PM
Oh and my throat is killing me from having a tube shoved down it.
Old 06-28-2019, 06:28 PM
Jesus man take care of yourself, who will stick up for me against Champ if you’re not here?
Seriously be well!
1977 RED TA
Old 06-28-2019, 06:31 PM
Back to topic....... 97 here today, tomorrow is supposed to be the worst day, and I have a show tomorrow I’ve never been to, looks out of my comfort zone, but I’m curious and it’s close to home.
1977 RED TA
Old 06-28-2019, 07:00 PM
Seriously be well!
LOL...Ow
This (hopefully) puts an end to series of hospital stays I had last year.
Thanks MA
  #38
Old 06-28-2019, 07:02 PM
fyrffytr1's Avatar
I turned my yard irrigation sprinklers on today and all I got was steam!
  #39
Old 06-29-2019, 10:57 AM
GT182's Avatar
I just did the same at 10:45AM. In the shade it was 95°s. Out in the direct sunlight it's..... hold on..... 112°s so far. But it will climb even higher by noon and on thru the afternoon. I'm about ready to go swimming in my koi pond.
I wonder how they get the temps out in Death Valley, and I'm glad I'm not out there to find out.
Gary
  #40
Old 06-29-2019, 12:34 PM
Scott Roberts Scott Roberts is offline
Its 88 outside at 12:30pm on it's way to 95deg. And inside the plant.........well, the pic says it all
