Old 07-08-2019, 12:20 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Any Pictures Of Your 68 or 69 GTO Turbo Downpipe At Firewall?
I'm curious how you all are running the single turbo down pipe at the fire wall since there is very little room in this area?
Any pictures would be helpful and how you're running the DP into the dual exhaust would be helpful too.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Intake & Rails, PTC 10" 0 Stat, Ricks Hot Rod SS Gas Tank, Magna 4303, Aerom EFI Reg, Aerospace Front & Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, Powersteering.com Pump & 12:1 Box, QA1 Front Arms & Viking Berz CO + Rear Shocks, Hella UP28 Vac Pump
Old 07-08-2019, 10:58 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
I have the engine out of the car as is.. I think I have all the exhaust after turbo still mounted up along with the turbo... I'll try to take a picture and post up for you.
With headers facing forward and the engine in stock location there is easily enough room for my single 4"....... I'm thinking a 5" should also be doable
These are tubing OD's btw....
Kris
*** THE BIG BRACE is here ***
Old 07-08-2019, 04:07 PM
JSPONT's Avatar
JSPONT JSPONT is offline
[ATTACH][/ATTACH]
3.5 inch down pipe, could fit 4 inch it's tight but the wrap helps the heat. I have a mid plate I clear also. I'll get more photos later for you
Old 07-11-2019, 06:31 PM
RUDOLFSSON's Avatar
I didn't forget you... Here's the 4" deal... (please, click them for larger photos)
Old 07-12-2019, 07:32 PM
Tom Vaught's Avatar
Boost Engineer
I personally think I would add a few full weld passes on those Turbo Mount Brackets vs the "spot welds" holding that heavy turbo to the frame. BUT it is a NICE mount arrangement.
Kind of like 70 birds mount.
Tom V.
Old 07-13-2019, 12:10 PM
JSPONT's Avatar
Old 07-15-2019, 05:24 PM
RUDOLFSSON's Avatar
Tom V.
It is fully MIG welded and has stayed there since 2007 with no issues..
Old 07-15-2019, 05:36 PM
Tom Vaught's Avatar
Boost Engineer
Sorry about that.
I expanded the photo, I was looking at the piece with two holes it it, I blew the picture up and see it is not part of the Turbo Mount.
Tom v.
Old 07-15-2019, 08:54 PM
RUDOLFSSON's Avatar
No problem Tom
Thread Tools
Display Modes
