Old 07-10-2019, 09:52 AM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
Default Changing from single to dual exhaust
I am getting close to changing from a single exhaust system.
I would like to use splitters, 64 LeMans, but not dead set on it due to the cost.
I have to get a set of down pipes, Ames price, $140.
The least expensive system listed is $479 and another $180 for mufflers.
Miscellaneous hangers, $70
So that comes to almost $900 not including having it installed.
If the price is what is normal now then I will go forward.
If someone knows of a less expensive route I would appreciate the info.
Anodized aluminum is fine, my current single exhaust is aluminum and has lasted 20 years.
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
Old 07-10-2019, 10:06 AM
Sirrotica's Avatar
https://www.ebay.com/itm/1964-1965-G...YAAOSwNNxWE-rI
$430 on Ebay aluminized, $85 shipping.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-10-2019, 10:11 AM
HALFWAY's Avatar
Thanks, I will look into it.
Old 07-10-2019, 10:27 AM
Sirrotica's Avatar
Just for grins and chuckles, most Midas shops also have the bending cards to make pipes back that far. I would inquire if you have one locally to see if they are willing to make a system and install it for you, would only take a phone call to see if they would want to make a system and install it.
I used to work at a Independent Muffler shop many years ago and we made systems from the cards that come with the pipe bender system. A friend also had a Midas Muffler shop and his cards also went back into the sixties to bend up complete systems from straight pipe. I used his bender to make a complete 2 1/4" system for my 76 T/A. As long as they have an operator that can follow the directions on the cards and has some patience the system usually fits fine.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-11-2019, 06:12 AM
Cardo's Avatar
Cardo Cardo is offline
Check Waldron''s too. http://waldronexhaust.com/cart/index...oducts_id=2826
"I know just enough to keep me here, but not enough to get me out"
Old 10-14-2019, 02:57 AM
android 211 android 211 is offline
Order some mufflers that you would like and take them to an independent muffler shop that bends pipe. Its the least expensive option generally.
If you just go for a straight dual system with no X pipe or H pipe, discount turbo mufflers and 2 1/4" pipe it should be reasonable and sound good for a long time.
Old 10-14-2019, 10:47 AM
Stuart's Avatar
Stuart Stuart is offline
Yes, check around in your area to see if there's an exhaust shop that works on old cars.
Old 10-19-2019, 12:49 PM
goatless's Avatar
goatless goatless is offline
FWIW, You can get a stainless 2.5" mandrel bent Pypes system from Summit Racing for as low as $545 complete with down pipes and mufflers. The Pypes systems come with hangers and clamps included.
If it's an otherwise stock 326 powered Lemans, that eBay system looks hard to beat. Maybe not the best from a performance standpoint, but fine for stock.
If you decide to go for the local muffler shop route- make sure you get some references- I'd hate to end up with a half-assed system with a huge price tag!
1966 GTO
Old 11-26-2019, 05:25 PM
389 389 is offline
Do yourself a favor and don't change it back into a single exhaust with an X pipe...
Old 11-27-2019, 07:46 AM
chrisp chrisp is offline
https://www.ebay.com/itm/Flowmaster-...sAAOSwy6ddv7FH
Aluminized system & the fit is the best .
Old 11-30-2019, 09:32 AM
389 389 is offline
That Flowmaster system Chrisp showed you is a very nice set up.. I have one similar to that on my 69 el Camino. I used Dynomax Super Turbo mufflers #17749.. It sounds really good behind a stock Impala 427 Big Block..
